zxr 750 h2
Phillip Summers
PostPosted: 00:22 - 11 May 2010    Post subject: zxr 750 h2 Reply with quote
Im having troubles starting my zxr 750. Each day it has to be bump started, however, after that it will start ok on the button. Once its running the idle is a little slow too.
Have checked battery and plugs and are both good.
Has anyone got any ideas- need it back on the road ASAP
Paulington
PostPosted: 01:09 - 11 May 2010    Post subject: Reply with quote
I assume it'd be something to do with the carbs then, doesn't sound like the engine is getting enough fuel when cold?
I may be wrong!
Billing
PostPosted: 01:34 - 11 May 2010    Post subject: Reply with quote
Maybe this would be better off in the workshop section rather than here Thumbs Up
Anyway, to me sounds like your battery may not be in the best of health, even though you said it was fine. The reason I say this is because it sounds like the battery is discharging a little overnight (do you have an alarm or anything?) meaning it doesn't have enough power to spin the starter motor and supply the coils at the same time. When you bump start it all of the available power goes to the coils and it fires up, then after you ride it around for a bit the battery gets topped up, so then can run the starter motor and the coils Thumbs Up
bacon
PostPosted: 01:39 - 11 May 2010    Post subject: Reply with quote
ask on www.redmonkey.com/7r
They know everything about zxr750's, zx7r's etc and likely to have a answer for you
base
PostPosted: 08:38 - 11 May 2010    Post subject: Reply with quote
my old h2 used to have to have a battery in tip top condition to spin it up to start, i have a feeling that the alternator belt might be slipping slighty and not charging the battery quite enough, this is a issue i used to have.
i assume that once its running it runs ok, not bogging down or anything? otherwise it could be a carb issue, as i had one of the carbs stick open this caused some starting issues and general running problems
PostPosted: 08:42 - 11 May 2010    Post subject: Reply with quote
H2s have belt driven alternators!? Shocked
base
PostPosted: 08:43 - 11 May 2010    Post subject: Reply with quote
Yes they do and they were the bain of my life Smile
DaveH
PostPosted: 08:52 - 11 May 2010    Post subject: Reply with quote
Why do you bump it? i.e. what are the symptoms of it not starting off the button?
https://www.timhastingsracing.co.uk/
ZX7R & ER6F
Damon
PostPosted: 12:29 - 11 May 2010    Post subject: Reply with quote
mine too, I think I replaced the belt 3 times in the half a year I owned a H2. Its no quick 5 minute job either Rolling Eyes
The last post was made 16 years, 115 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 60.13 Kb
