engine mount bolts
dobby
PostPosted: 13:21 - 11 May 2010    Post subject: engine mount bolts Reply with quote
i have a 2007 cr 85 and have removed the front engine mount bolt and the bolt from underneath but the rear one which goes through the swinging arm and the engine is being awkward to remove... ne ideas on how to remove it? or do i have to undo the suspension nut at the to to allow it to be able to move about more freely incase it is just seized to that or just the engine???
other than that any other ideas on how to remove it???
many thanks....
PostPosted: 13:33 - 11 May 2010    Post subject: Reply with quote
Is it turning? Common problem can be the bolt seizing into the bushes in the swinging arm.
dobby
PostPosted: 13:39 - 11 May 2010    Post subject: Reply with quote
no it doesnt keith, ive tried a big pair of long nose pliers on it but can get it to turn or to go forwards, if i can just move it out of the frame a few mm then it would be ok to get a spanner onto the flat side n twist it... ive tried covering all of the little gaps in it in plus gas n leaving it but not aving much luck....
PostPosted: 13:42 - 11 May 2010    Post subject: Reply with quote
Can you post a few pics?
I would expect a nut on one end. The other end of the bolt might be a normal hex head or might just have a couple of flats and fit located in the frame. In either case once the nut is off the bolt should knock through.
dobby
PostPosted: 13:48 - 11 May 2010    Post subject: Reply with quote
il get pics this afternoon, it has 2 flats on one side and a nut on the other side
PostPosted: 14:00 - 11 May 2010    Post subject: Reply with quote
Once the nut is off it should just push through (at which point you find that the bike wasn't securely supported and collapses in a head Wink ).
The last post was made 16 years, 127 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 48.55 Kb
