| Ingah |
 Ingah World Chat Champion
 Posted: 18:53 - 11 May 2010 Post subject: Keeping Tyres in contact with the road |
I find riding at a brisk pace on these uneven Welsh roads to be a little bum-clenching at times due to the many many relatively minor bumps, holes and dips in the road (i couldn't swear to it, but it does often feel like the bike's tyres keep losing contact with the road surface momentarily). It detracts alot from my enjoyment of taking corners because of the fear that the bike may not recover properly and send me off, over cliff edges and into the side of mountains (it's very "Welsh" geographically round here)
Because of the bike's age, i'm tempted to blame the bike (it's a 1995 CB500 with nearly 50K on the clocks). However, i don't have the experience to know whether it really is the bike, or whether it's supposed to be like that (i.e. motorbike tyres often feel like they're leaving the road surface and it can't be modified not to do that).
I've replaced a great deal of parts with new on the bike since buying it (relevant things to this probably being the front fork oil and seals, rear wheel bearings and head bearings), and it's finally got to the stage where i can think of replacing parts to improve the bike rather than simply to keep it running properly. Hence this issue is something i'm looking at.
The 2 modifications springing to my mind are progressive (or otherwise improved) front fork springs - i've already been told the fork oil i'm using is high quality. I am unsure if this will help or not though, as i don't think i want a harder ride. The other thing (probably biggest thing) is the rear suspension units, of which i'm thinking of buying Hagon at £120 (not a cheap mod considering the age of this bike). Currently though, the front wheel bearing has slight play, and so that is definitely next before i start any "improvements".
Note: The current rear suspension is definitely not "broken" (in that when pressure is applied to the rear of the bike, it comes up again gradually and smoothly as i expect it to). And it's only adjustable property is the pre-load.
I'm just hoping for ideas and advice (and hopefully to be reassured that replacing the rear suspension isn't going to be largely money down the toilet!), because i don't think i ride very fast, but the bike worries me enough to prevent me relaxing enough to go faster! ____________________ -- Ingah |
| AJ |
 AJ Nitrous Nuisance
| garth |
 garth World Chat Champion
 Posted: 19:18 - 11 May 2010 Post subject: |
I tend to spend most of my time making the wheels come off the ground.  ____________________ You ain't a has been if you never was |
| Ingah |
| doggone |
 doggone World Chat Champion
| Walloper |
 Walloper Super Spammer
| Acemastr |
 Acemastr World Chat Champion
| Paxovasa |
 Paxovasa World Chat Champion
 Posted: 10:35 - 12 May 2010 Post subject: |
Check the tyre pressures also  ____________________ Suzuki GSF600 K3 (in the fastest colour, black). |
| Ingah |
| Paxovasa |
 Posted: 17:04 - 12 May 2010 Post subject: |
40 psi rear seems high to me.
But if that is what is recommended than fair enough.  ____________________ Suzuki GSF600 K3 (in the fastest colour, black). |
| chris-red |
| Ingah |
| njd27 |
 njd27 Trackday Trickster
| Ingah |
 Posted: 17:38 - 12 May 2010 Post subject: Re: Keeping Tyres in contact with the road |
| njd27 wrote: | | Ingah wrote: | The 2 modifications springing to my mind are progressive (or otherwise improved) front fork springs - i've already been told the fork oil i'm using is high quality. I am unsure if this will help or not though, as i don't think i want a harder ride. The other thing (probably biggest thing) is the rear suspension units, of which i'm thinking of buying Hagon at £120 (not a cheap mod considering the age of this bike). Currently though, the front wheel bearing has slight play, and so that is definitely next before i start any "improvements". |
We've got two CB500s. Mine is a 2000 with 45k on it, still on the original rear shocks. My OH's is a 1994 with 37k and last year I replaced the rear shocks with new Hagon ones because the previous ones had completely seized.
The Hagon shocks are definitely stiffer than the stock items but obviously the bike feels someone more unsettled over potholes/bumps as a result. It doesn't help that the tyres are very squared-off on that bike.
It sounds like it's pretty worn out to be honest - why not sell it and buy something newer and more interesting? |
Because i'm a student with no guaranteed home address to register with an insurer for a reasonable price (i live with my missus and her family - the bikes are registered there atm, but you never know...) and since i bought the bike 14/15 months ago i have fixed/replaced (this is not even a comprehensive list it's just what i could remember):
Coolant leak.
Rear wheel bearings.
Chain and sprockets.
Front tyre.
Rear tyre (losing pressure, slow puncture).
Head bearings.
Starter button.
Indicator buttons.
Front fork seals and fork oil.
Ignition switch (unit).
Speedo drive (unit).
Speedo cable.
Front brake hose (replaced with Goodridge braided).
Both mirrors.
Brake lever.
Speedo / rev counter backlights.
Fuel filler cap.
Rear brake drum seized.
I've also fitted a chain oiler, the bike has engine bars. There are a few other practical modifications too that i can't remember right now. I've also had _everything_ serviced, including things like valves, air filters etc.
Front wheel bearings are next!
Thing is after all that i wouldn't get a penny of it back if i sold the bike. Having got largely new parts on the majority of the bike, it seems like a bad idea to move from this (now) largely new machine on to another old potential heap of future issues doesn't it?
I've been rather amazed by how expensive replacement parts were for this bike (my other bike is a CG125 you see), let alone a 600 or something. I also find it heavy (it's very hilly around here) and a 600 is likely to be worse in that way. ____________________ -- Ingah |
| njd27 |
| multijoy |
 multijoy World Chat Champion
| Tig |
 Tig Nova Slayer
 Posted: 19:57 - 12 May 2010 Post subject: |
| multijoy wrote: | Have you tried dropping the pressures? I run my CB500 on the 29/36 settings and what you're describing has never been an issue. Granted, I'm using Avons, but I doubt there's much in it. |
I'd second this option first, as it's by far the cheapest and quickest to try, just to see if it does make a difference at all? You can always go back to the higher PSIs if not
cheers
Tig ____________________ YB100, XS250, GPZ305, VT500, XJ900, XV535, XL125, a scratched up ZZR600 :-S |
The last post was made 16 years, 120 days ago. Instead of replying here, would creating a new thread be more useful? |
