| ash t |
 ash t World Chat Champion
| Alexio |
 Alexio World Chat Champion
 Posted: 06:59 - 12 May 2010 Post subject: |
Your problem appears to be that it is not a bike.
I'm not sure why I'm replying as I don't know much about cars but I imagine the only things to check is the suspension / shock absorbers as you mentioned, equal tire pressure (although I assume the car isn't steering off center?), a healthy differential / rear axle and wheels that are properly balanced. Maybe your lug nuts are loose and your wheel is about to literally fall off, who knows  ____________________ will never give up his CG. I look at my fuel gauge more as a progress bar than a fuel gauge.
ms51ves3: why does it need 500 miles? Are you teaching it how to be a piston? |
| Walloper |
 Walloper Super Spammer
 Posted: 08:41 - 12 May 2010 Post subject: |
Doubts on it being a wear factor problem. Shockers should be good for much more than four years.
A lumpy tyre may be the cause.
You say there is a 'knock' on a wheel. How did it get that?
Chances are the tyre was gubbed when it got the 'knock'.
It may not have been noticeable at the time of the incident as the tyre had more meat on it. As the tyre wears the protection/structural integrity is now not enough to prevent a bulge forming.
Quick check is to put the Knocked wheel on the front and see if you get a massive wobble.
If no then do the same with the other side.
That should eliminated wheels from the equation and it cost you nothing.
Or you are now 'already' noticing the effects of a Conservative Government's hopeless attitude to road maintenance.  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| ajbsmirnoff |
 ajbsmirnoff World Chat Champion
| kingsmith |
 kingsmith Scooby Slapper
| Robby |
 Robby Dirty Old Man
| jimspeed |
 jimspeed World Chat Champion
The last post was made 16 years, 135 days ago. Instead of replying here, would creating a new thread be more useful? |
