Help - Bike Identification!
TERRIER7
PostPosted: 22:07 - 12 May 2010    Post subject: Help - Bike Identification! Reply with quote
Hi all, I have recently acquired a couple of bikes for my children. Someone has taken some parts off one, I need to ID it so that replacements can be obtained. The problem is that there is no plate apart from a serial number. The sticker states it is an SD50FD and the word 'sport' appears on the mini front fairing. Can anyone help with a) ID and b) let me know if they are breaking a similar model as I need throttle linkage and one or two minor parts. I attach a few photo's.
The kick start has failed on the other. This time I am a little luckier with the ID, it is a Beta 50 Crosser. I need a kick start pinion drive cog, anyone no where I can get one?
kind regards
T7
T7
That_Hornet
PostPosted: 22:09 - 12 May 2010    Post subject: Reply with quote
The majority of Chinese minimotos are the same engines, carbs etc.
What parts you missing?
Ant132
PostPosted: 22:10 - 12 May 2010    Post subject: Reply with quote
A Chinese copy of the Yamaha PW50?
Maybe the Yam parts will fit, should be easier to source! Thumbs Up
Moo.
PostPosted: 22:12 - 12 May 2010    Post subject: Reply with quote
Id take that bet too Wink
A2 Passed 18/6/10
TERRIER7
PostPosted: 22:16 - 12 May 2010    Post subject: Identification Reply with quote
Thanks that Hornet, I have a little difficulty in being sure as I do not have a book; the throttle cable is missing, also there appears to be a dual linkage 'plug' which ends, might just be visible on the photo. Two cables go into it, one from the carb, and the connection up to the handlebar is missing. Might be the same as the main throttle cable. Also a spark plug and cap, although once the plug is identified, I can fix up a cap.
Also thanks to Ant 132, I will try to find one to look at, good info!
T7
Ciar?n
PostPosted: 22:55 - 12 May 2010    Post subject: Reply with quote
Looks identical to my PW50
https://sphotos.ak.fbcdn.net/hphotos-ak-snc3/hs039.snc3/12639_186541801851_579616851_3495332_2917476_n.jpg
The last post was made 16 years, 122 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 47.29 Kb
