Think my alternator died?
alt
PostPosted: 12:45 - 12 Jul 2004    Post subject: Think my alternator died? Reply with quote
I hadnt run my NSR 125 '00 for quite a long time, when I went to run it last week it started fine, but the elctronics wouldnt work. The indicators/headlights were very flaky, sometimes they would work, sometimes they wouldnt. Then I turned on my headlights/indicators the RPM meter and Temp gauge went dead, until i turned the indicators/headlights off.
Yesterday I went to start the engine to give it a run, and nothing happened. It is cmopletely dead. I've checked all obvious things like battery charge (its charged fully) and connections.
Anyone got any suggestions?
Sparks!
Sir Tart-a-lot
PostPosted: 12:49 - 12 Jul 2004    Post subject: Reply with quote
Sounds more like a flat/dead battery... get a charger and leave it on over night and try again, if not then bump start the bike and go for a long ride.
The same thing happened to 30sumthin_gal's NSR the other week, all I done was bump start it and go for long ride and it's been fine ever since Shocked
Worth trying Thumbs Up
<EDIT> by the way, you can test the reg/reg etc using a multimeter across the battery terminals, test with ignition on, bike ticking over, and with light revs.. test with lights on and then with lights off etc.. and record the multimeter readings and match them up with a manual or post them on here Thumbs Up </EDIT>
alt
PostPosted: 13:26 - 12 Jul 2004    Post subject: Reply with quote
Thanks,
Will do what you suggested when I get home and post my recordings
craigT19
Jolly Green Giant
PostPosted: 13:39 - 12 Jul 2004    Post subject: Reply with quote
the nsr's electrics are incredibly bad, there always blowing bulbs and batterys if that doesnt work try looking at the main fuse thats conected to the battery, at one point mine started to fall apart leading to similar problems
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
rsooty
PostPosted: 13:52 - 12 Jul 2004    Post subject: Reply with quote
Do you have an alarm fitted? It sounds like something has just drained the battery. The alternator only works when the engine is running so if it has being left running something while the bike is not in use it will drain power. Check the battery for charge, if their is no power at all you may need to buy a new battery.
Sooty
The last post was made 22 years, 97 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 44.68 Kb
