Derbi Gpr 50 - 3k revs and no more
snowdude2004
PostPosted: 18:37 - 14 May 2010    Post subject: Derbi Gpr 50 - 3k revs and no more Reply with quote
A week ago my Derbi gpr 50 year 2000 would not start. I went for a long ride and when I went to go back out on it an hour later after leaving it on my drive it just would not pull away. A few days before the problem I had changed the gearbox oil for 10w40 gear oil from Halfords and about 1/2 weeks before that I put about 20ml of redex in a full tank.
Before this problem occurred I had a couple of issues on the bike, occasionally the starter button would not respond and the indicators would flash like mad. Also when in third gear onwards it would not go past 10k revs so I checked my sprockets and found out the rear was 50 teeth and the front was 14 teeth which seemed far from standard so I'm guessing that just needs the standard sprockets again. Was a bit crap up hills aswell but I believe it may of been because of this problem.
When I start it, it is at 1.5k revs or so with the choke open and when giving it full throttle it just about picks up to 3k revs and will just not go any further. The throttle seems to be unresponsive. When I took out my spark plug and put it on the cylinder to check for sparks it was a small blue spark as it should be as air pushed out of the spark hole plug as it should as well as a strong smell of petrol, if thats normal?
Since then I have done the following:
* Replaced spark plug
* Took off airbox and checked it
* Took apart carb and re assembled it
* Re charged battery
* De coked exhaust
* Checked fuel line from petrol tank and carb and both are receiving petrol
* Checked throttle cable to carb was still tensioning when twisting throttle
* Was almost on reserve so filled up the tank with petrol
I'm completely baffled for ideas now, Any ideas people?
CBT passed: 26/09/09, Theory Passed: 18/08/10, Mod 1 passed: 20/10/10, Mod 2 passed: 26/10/10.
Current Bike: Honda CBR 400 Nc23
snowdude2004
PostPosted: 16:47 - 18 May 2010    Post subject: Reply with quote
Bump...
snowdude2004
PostPosted: 20:08 - 18 May 2010    Post subject: Reply with quote
Just sprayed easy start into carb with airbox off and on the inlet on the airbox when it was on and there was no change on my rev counter what so ever.
Also just did a compression test and received a reading of 90 psi....
snowdude2004
PostPosted: 20:55 - 18 May 2010    Post subject: Reply with quote
already changed my coil over with other one which I broke ht lead off of so just transferred that across and no change
snowdude2004
PostPosted: 22:09 - 19 May 2010    Post subject: Reply with quote
Finally got a compression gauge and have now found out that its only getting 80/90 psi.... Don't know what I can do to increase it now though.
PostPosted: 22:24 - 19 May 2010    Post subject: Reply with quote
Rebuild the top end properly...im fairly sure around 110-130 is ok..below is getting iffy. My current KH is apparently turning out 128psi... and ive ragged that thing Smile
snowdude2004
PostPosted: 22:41 - 19 May 2010    Post subject: Reply with quote
How would you go about rebuilding the top end properly exactly?
snowdude2004
PostPosted: 22:56 - 19 May 2010    Post subject: Reply with quote
I don't know what it entails exactly, e.g new piston/piston rings.
The last post was made 16 years, 47 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.59 - MySQL Queries: 13 - Page Size: 64.56 Kb
