sprockets
alnicci
PostPosted: 20:18 - 14 May 2010    Post subject: sprockets Reply with quote
where do i buy a larger sprocket from for my derbi senda 125 to give me a bit more top end spead do i go to a normal bike shop or do i have to find a specialists had bike from dk newcastle staffs any advise thanks al. Idea
Deckx
PostPosted: 20:48 - 14 May 2010    Post subject: Reply with quote
you need a smaller back sprocket to get more top speed, this will make the bike higher geared but you lose low end power so first might feel a bit like second.... should be able to order in any bike shop
PostPosted: 20:58 - 14 May 2010    Post subject: Reply with quote
Looking at the JT Sprockets site there are a few different sizes available for some models of Senda. As such your normal dealer should be able to get one fairly easily.
Failing that B&C Express should be able to make one up for you (but that works out rather more expensive).
PostPosted: 08:51 - 15 May 2010    Post subject: Reply with quote
I've used B&C express before for custom sprockets and been pleased with the result - I called them up yesterday and there's currently at least a 10day wait for your order.
Remember it will only go faster if it will easily top out in top gear already - if it won't it will likely make it slower. So if it doesn't already top-out, slight down gearing can actually improve top speed as it can make full use of the power.
alnicci
PostPosted: 20:56 - 15 May 2010    Post subject: thanks for your advise Reply with quote
a long time ago when i was 17 i had a honda cb100n and i changed the front sprocket to a larger one which didnt realy affect me pulling of realy but gave me about 5mph top end more is there much difrence in changing the front or rear sprocket thanks al .
PostPosted: 22:24 - 15 May 2010    Post subject: Re: thanks for your advise Reply with quote
One up on the front is approximately equal to three down on the rear.
If you had 15/45 sprockets, it would be pretty much exactly equal.
As I say though - it's only going to increase it if you're definitely maxxing it out in top, otherwise it may well reduce your top speed.
The last post was made 16 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 47.38 Kb
