Rear lights & clock illumination problem.
Misc
PostPosted: 01:00 - 15 May 2010    Post subject: Rear lights & clock illumination problem. Reply with quote
Evening/morning.
As above the rear lights & clock illumination aren't coming on. All fuses are fine & when i take a piece of wire & place one end at the +ve terminal on the battery & the other end on the brown wire on the rear light connector everything comes on as it should.
The problem came up when i removed my headlights.
Does this usually mean a wire is loose somewhere or broken? Does the fact that the lights came on as above narrow it down?
I picked up a multimeter today so going from the diagram below, what's the best way to use it & at what points on the circuit?
Also, on the tail light there is a Black/White wire & then a White/Black wire. What's the White/Black one for?
I've also currently got my horn, front indicators & headlight unplugged, i'm sure this wouldn't be the problem but may have something to do with completing the circuit.
Thanks.
Wiring diagram:
https://img693.imageshack.us/img693/1770/11213w.jpg
V2
PostPosted: 02:20 - 15 May 2010    Post subject: Reply with quote
Ive modded the diagram as to where i would test, Red dots where i would expect to see +12v and black dots where i would expect to see ground (meter on ohms and small resistance back to battery -ve terminal) By looking at the diagram i think the white/black is your brake light, there will be 3 wires going to that light, Rear light filament, Brake filament and ground, if you look at your rear light bulb it should have 2 filaments inside it
https://www.bikechatforums.com/files/11213wc.jpg
Misc
PostPosted: 10:10 - 15 May 2010    Post subject: Reply with quote
Thanks a bunch for that, will have a look then give it a go. Thumbs Up
The last post was made 16 years, 147 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 36.5 Kb
