| skatefreak |
 skatefreak World Chat Champion
 Posted: 15:28 - 14 May 2010 Post subject: need an NSR wizard! *Cough*alains*Ahem* :p |
But yeah seriously,
I'm now stumped!
I had a little go over the bike (really need to give it a good strip i think), and discovered a cable... Just sitting there doing nothing.
That dosnt seem right i though.
Turns out it comes out a bit coming off the side of the combustion chamber at the exhaust port.
Power valve i thought.
There is only one of the two cables coming out of there attached to a cylinder that i gues must be the rc servo but the other end has been left un attached. There is also a screw on the cylinder so i dont think it can actually move
So this leads me to suspect the valve is open all the time so i was wondering if anyone could let me know how this would effect the performance of the bike as it seems to whoosh when its supposed to (7k-8k it starts) and isnt to funky in the lower end either.
Sooo, i'm guessing there is certainly something up with this bike and it may explain why i'm getting not so great mpg as well.
The bike seems to ride fine although i'm sure someone mentioned in a thread a while ago that sometimes the powervalves are fixed open to cover problems
Would it be covering big problems that are likely to get expensive or could they be fixable? I have a spare engine that looks to be in good nick with all the attachments (including radiator etc but excluding a starter haha. typical).
Any thoughts on the subject would be much appreciated.
Best regards
-Jvr
Ps, the picture may help... |
 ---- World Chat Champion
 Posted: 17:47 - 14 May 2010 Post subject: |
Probably is the P.V. although i'm not too familliar with nsr's
Pegged open powervalve (cables would be removed to do this) you would have no power below 7k then everything comes in at once above that.
You could just put it back to standard by unpegging the P.V and re-fitting the cables quite easily if the servo still works (or you have a spare for that anyway?)
MPG would be much better with it working as you don't have to work the engine as hard...
HTH
EDIT: some people prefer the power delivery with it pegged open so might not be covering a fault,but worse case it's only going to be the servo. ____________________ DRZ-400sm |
| skatefreak |
 Posted: 18:30 - 14 May 2010 Post subject: |
Hey,
Cheers for the info.
Jst done a good 30 miles on it and am still confused, it pulls below 7k but not so well.
Will connect it back up and take out the screw and get back to you, may be a next week as manic coding for uni project in on monday
Best regards
-Jvr |
| G |
 G The Voice of Reason
| st3v3 |
 st3v3 Super Spammer
| alains |
 alains World Chat Champion
| skatefreak |
 Posted: 15:57 - 16 May 2010 Post subject: |
Superb, appologies for not being around much, mucho's uni work ?
i will have a look monday afternoon once i get this project handed in
Best regards
-Jvr |
The last post was made 16 years, 165 days ago. Instead of replying here, would creating a new thread be more useful? |
