Encryption
CaNsA
PostPosted: 22:08 - 15 May 2010    Post subject: Encryption Reply with quote
I have a 300gig external usb, portable hdd.
I need to encrypt it in a way that i can plug it into any other computer, enter the "key" and use it.
no software can be installed on the other computers.
Ideas?
cheers
Phoenix
Twisted Firestarter
PostPosted: 22:45 - 15 May 2010    Post subject: Reply with quote
Depends what the use is and what it is you want to encrypt, there's probably software specifically for it. You could just turn the stuff into an encrypted self ectracting zip archive with a password, set the compression level to zero and it'll be nearly as quick as a straight file copy.
Burnside
PostPosted: 22:47 - 15 May 2010    Post subject: Reply with quote
We use Utimaco Safeguard and Becrypt on USB hard drives at work cos they're FIPS-42 certified, you only need to input one password when the device is plugged in, nothing needs to be installed on the PC.
Truecrypt is open source with AES 256bit certification but I've never used it, not sure how straightforward it would be for removable devices. But hey, its free Smile
I started out with nothing and I still got most of it left.
temeluchus
PostPosted: 00:35 - 16 May 2010    Post subject: Reply with quote
WinRAR can do that and is free.
Aka Matt
PostPosted: 00:41 - 16 May 2010    Post subject: Reply with quote
I found truecrypt very straight forward to use and it also offers a variety of different encryption types too depending on the level of security you are after.
Current bike(s): 2016 Tuono 1100 Factory, 1998 Hornet 600
Previous: 1998 YZF600R Thundercat, 2001 Bandit 600, 2002 GSX-R 600 K2, 2011 Tuono R, 2013 Z1000SX
CaNsA
PostPosted: 08:04 - 16 May 2010    Post subject: Reply with quote
Cheers for the replies peeps.
@ Phoenix
Using compression software wont work as no software can be installed/ran on the other computers.
And Winzip/Winrar passwords are not secure.
@ hollyj
Been checking out the software u mentioned, can i have a copy Wink
I have been playing with truecrypt, its quite fiddly. Hopefully i have sussed it. I will have to wait until monday to test it out in work. I wounder how the NHS network will respond to it.
@ Temeluchus
Cant trust a Nietzschean......
@ Evil Dude UK
Simple encryption has been easy to set up. But a portable, automount, enter password and access system has been a complete arse to config.
tsmith
PostPosted: 19:17 - 16 May 2010    Post subject: Reply with quote
For software solutions, check out Truecrypt, PGP Disk or Drivecrypt
Hardware solutions check out https://www.enovatech.net/solutions.htm
Phoenix
Twisted Firestarter
PostPosted: 22:04 - 16 May 2010    Post subject: Reply with quote
Self extracting archives don't require any software on the destination computer, that's the idea behind them. Winzip/WinRAR passwords are just as secure as any, you just have to make sure it can't be found by a dictionary attack ie make it alphanumeric and nonsensical to a dictionary.
CaNsA
PostPosted: 22:35 - 16 May 2010    Post subject: Reply with quote
Cheers Tom,
Ill give them a go. the "on the fly" feature is what im after.
Yeah, well done like... but how can i encrypt the altered data afterwards with out installing the software?
Dude, its easy to pull files from a password protected archive.
they get stored in a temp location until the password is entered.
Phoenix
Twisted Firestarter
PostPosted: 13:35 - 17 May 2010    Post subject: Reply with quote
Not in self extracting archives they don't, password first, then extraction Rolling Eyes
And "yeah, well done like", well I did say in the very first post that you haven't said what exactly you are planning to do so I assumed it was files you needed access to, not to work off the hard drive and save more to it, for all I know it's just to read files from another computer.
You know best, you figure it out.
The last post was made 16 years, 113 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 65.64 Kb
