| rob_scott92 |
 rob_scott92 Could Be A Chat Bot
 Posted: 22:57 - 15 May 2010 Post subject: Snapped side panel fixings |
Heya,
When i bought the cb 350, one of the fixings on the side panels had snapped (One of two) the other day i was taking the panel off and the other one decided to go and snap off What kind of stuff would be good to re-glue these back? I've heard that theres some pretty good adhesive used for pvc conduit, good as in, you better hope its in the right place when you glue it coz it aint gonna move
Anyone know if this stuff will be good on the panels?
Cheers
Rob  ____________________ First bike: 1982 Suzuki Gs 125 'The beast MK1' > 1988 Honda Cb 350's' FOR SPORT! (Good ol' oil burner!) > 2001 Suzuki Sv 650 's' Made it out of the 80's! > 1997 Honda Cbr 600f :p |
| JacPowell |
 JacPowell Renault 5 Driver
 Posted: 23:14 - 15 May 2010 Post subject: |
Good old superglue ! No, really  |
| rob_scott92 |
 Posted: 23:24 - 15 May 2010 Post subject: |
did think superglue but not sure if it'll do. I mean think about it, the side panels are likely to be taken off and put back on fairly regularly, so wont take long for them just to snap off again . ____________________ First bike: 1982 Suzuki Gs 125 'The beast MK1' > 1988 Honda Cb 350's' FOR SPORT! (Good ol' oil burner!) > 2001 Suzuki Sv 650 's' Made it out of the 80's! > 1997 Honda Cbr 600f :p |
| JacPowell |
 Posted: 00:06 - 16 May 2010 Post subject: |
Iv done it on mine just sand it down afterwards and a quick spray of clear coat on top go out and get it filthy and youll never know  |
| Noxious89123 |
 Posted: 00:37 - 16 May 2010 Post subject: |
Superglue is rubbish, it just ends up brittle. Fibreglass resin has worked very well for me before, but tends to end up a bit messy.
Someone was asking a similar question last week and was recommended... PlastiFix i think it was? Or somthing like that. It was a proper plastic repair stuff, should set as strong as when the plastic was new.
The problem with superglue is that the 2 peices of plastic don't bond with each other, they bond to the glue. That's why it ends up so weak.
Someone also recommended getting some acetone (nail varnish remover) and dropping a plastic lego brick into it, and using the resulting melted plastic goop to stick parts back together. Think it was Virus? ____________________
| hondapartsman |
 hondapartsman Renault 5 Driver
| Ichy |
 Ichy World Chat Champion
| cyberglass |
 cyberglass World Chat Champion
 Posted: 09:13 - 16 May 2010 Post subject: |
Get a drill as small as possible and drill 2 tiny holes into the lugs and matching holes in the panels. superglue a couple of staples into the lug then line the lug up and glue it into the panel.
Will give you a reinforced bond which is hard to break.
Its fiddly to do though.
you can also use bits of paperclip cut to length. ____________________ DL650 Vstrom 2004
DRZ400S 2003
Yamaha R1 2005 |
| Walloper |
 Walloper Super Spammer
 Posted: 09:15 - 16 May 2010 Post subject: |
'Plastex' (or the 'Plastex' Look-a-like out of Halfrauds)
https://www.plastexexpress.co.uk/
Nothing else is worth the time and effort.
Plastex welds the parts or lets you 'clone' a perfect match for something that's broken i. e. a spring-nut lug. ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| subby631 |
 subby631 L Plate Warrior
| rob_scott92 |
 Posted: 16:17 - 16 May 2010 Post subject: |
Thanks guys, sounds like theres lots of stuff available so thats good. As i'm doing an electrical course at college (Where i heard about the stuff for pvc conduit) I'll ask my tutor about the stuff he uses. Might be cheeky and ask if he's got any in his van he can spare
The last post was made 16 years, 170 days ago. Instead of replying here, would creating a new thread be more useful? |
