Confused - bleed or topup brake fluid?
richrock
PostPosted: 14:12 - 16 May 2010    Post subject: Confused - bleed or topup brake fluid? Reply with quote
Like the subject -
I've been told I can top up the master cylinder reservoir, but cannot find any evidence that this is done on Google...
So - can I top up the brake fluid, or is it a complete bleed job?
Unsure as the level seems to vary from hour to hour at the moment....
I has a motorbikes: Kawasaki GPZ500s (1999)- theory passed 12/06/12, test passed 10/07/12
TUG
PostPosted: 14:23 - 16 May 2010    Post subject: Reply with quote
What do your pads look like? Low on friction material? The fluid goes lower as the piston pushes out more.
To top up fluid is just like topping anything up, just put some more in, Bleeding is to remove old fluid and air from the system, if the fluid hasn't been changed in a while it can make braking a hell of a better experiance.
Haz ER-5, innit!
richrock
PostPosted: 14:25 - 16 May 2010    Post subject: Reply with quote
I'll have a look - reckon the fluid got changed recently at the last service, and probably hasn't been bled properly.
Pads look new, they're plenty grippy, but the fluid level dropped quite a bit since yesterday.... Confused
Quote Me Happy
PostPosted: 14:28 - 16 May 2010    Post subject: Reply with quote
The fluid shouldn't really be noticeably dropping as it's a closed system i.e. the brake fluid doesn't get used up.
Have you checked for leaks?
TUG
Check for leaks. If its got rubber hoses on then they can tear and you'll lose both compression and fluid. or if it had new seals fitted any where check them also.
Seems quite odd.
Haz ER-5, innit!
richrock
PostPosted: 14:31 - 16 May 2010    Post subject: Reply with quote
Had a look, cables seem fine, did a few firm squeezes on the brakes and nothing seemed to seep from the piston area, on the cable or even the brake levers.
The brake pads themselves are plenty thick.
Can really only think that it wasn't bled. I'll get some more fluid and top up, plus keep a check on it this week. Thanks!
TUG
PostPosted: 14:32 - 16 May 2010    Post subject: Reply with quote
I'm guessing its a YBR125? The brakes are shit on them, and the reading will change based and where you turn the handle bars, if theres any imperfections, i.e. bump on the floor or something you will get a false reading. YBRs tend to be a bike that problems don't occur on, specially with the injection range.
Haz ER-5, innit!
richrock
PostPosted: 14:41 - 16 May 2010    Post subject: Reply with quote
Actually, now you mention that, I *did* alter the levers to suit my hands last night.... Embarassed
TUG
PostPosted: 19:22 - 16 May 2010    Post subject: Reply with quote
That would alter the level slightly. Thumbs Up Wink
I thought it was odd, i love working on those bikes, so simple and hard as nails. Thumbs Up
Haz ER-5, innit!
The last post was made 16 years, 168 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 59.48 Kb
