Yamaha R6 LED indicator problem
Jockster
PostPosted: 11:12 - 17 May 2010    Post subject: Yamaha R6 LED indicator problem Reply with quote
Since buying my R6 a month ago the LED indicators have stopped flashing correctly. At first they were 'as normal', flashing at the correct speed etc. For the past few weeks I have noticed that whenever switching the indicators on they will flash for a split second then not work at all. This is quite strange as when engaging and disengaging the alarm they flash correctly but its just when trying to use them on the road which is the problem. I don't think it is a loose wire as they work correctly for the alarm, just not when out on the road. Could this mean the resistor has gone? Does anybody have any ideas as to what the problem is?
Jock
PostPosted: 11:17 - 17 May 2010    Post subject: Reply with quote
Sounds like the flasher unit to me.
Jockster
PostPosted: 12:05 - 17 May 2010    Post subject: Reply with quote
Do you know where I would find the flasher unit on the bike?
Jockster
PostPosted: 14:03 - 17 May 2010    Post subject: Reply with quote
Thanks for the diagram, I think I will go out and get a new flasher unit to see if this is the problem.
cheers
Jock
Jockster
PostPosted: 15:59 - 26 May 2010    Post subject: Reply with quote
I've been told there are 2 types of flashing unit, a 2 pin & 3 pin variant. does anybody know what is used in a 2005 R6?
PostPosted: 16:09 - 26 May 2010    Post subject: Reply with quote
Pull it out and see, it shouldn't be hard, turn your ignition on and turn the indicator on. You will here the flasher unit, It is the thing that clicks.
TUG
PostPosted: 19:30 - 26 May 2010    Post subject: Reply with quote
Yours is a 2 pin and its under the CDI/Igniter box directly under the riders seat, personally i'd refit the stock indi's as they look best.
Haz ER-5, innit!
gray84
PostPosted: 21:46 - 26 May 2010    Post subject: Reply with quote
i had a big problem with mine mate i fitted led indicators and all was fine for a few weeks. the relay went and when i bought a new one is stayed the same i got stressed and said a few bad words along the lines of FOOKING BIKE I HATE YOU!! and then i found out i needed a aftermarked "led" relay and i bought this and all is/was fine then so keep that in mind.
the led relay is only needed if you have x2 sets of led indicators..
gray
The last post was made 16 years, 106 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 54.93 Kb
