Lube?!
skatefreak
PostPosted: 15:31 - 17 May 2010    Post subject: Lube?! Reply with quote
Hey,
So i rebuilt my starter a while back and it sounds horrible as its not lubed in there atall.
I am going to replace a gasket (left engine side) so figured i may as well get the starter out.
The part that rotates (picture 1) was completely dry when i stripped the starter and cleaned it, it runs on bearings either end so i figure that dosnt need any lubrication (grease the bearings somehow, although their shielded) however the gears etc (picture 2) will need some.
Sooo, what to use? I have some all purpose grease (loverly stuff!) but someone suggested petrolium jelly (vasaline). It sounds strange to me to be honest but has anyone else heard/come accross this?
Would the grease be a bad idea or should i try the vasaline? I'm not to keen on taking it all appart in a few months as i suspect the vasaline may not stay put.
Any thoughts would be much appreciated.
Best regards
-Jvr
chillyman0
PostPosted: 15:39 - 17 May 2010    Post subject: Reply with quote
dunno if you should use grease but i would say use high speed roller bearing grease or some sort of centrifugal grease. dont know where you can get any, i use some industrial stuff that my grandad has had for years haha
dunno if that helps Neutral
1996 gsf600n (sold)
trisers
PostPosted: 19:22 - 18 May 2010    Post subject: Reply with quote
I definitely wouldn't use vaseline, as soon as some of the engine heat warms it up it will go everywhere!
Bloggsy
PostPosted: 19:27 - 18 May 2010    Post subject: Reply with quote
coppaslip, used sparingly
TUG
PostPosted: 19:38 - 18 May 2010    Post subject: Reply with quote
I thought they lubed themselves with engine oil on the inside of the bike?
Atleast i was under the impression theres a seal around the starter motor to stop oil leaks.
Haz ER-5, innit!
Frost
PostPosted: 20:01 - 18 May 2010    Post subject: Reply with quote
That stuff is abrasive and would be line using a mild grinding paste on it.
dobby
PostPosted: 08:51 - 20 May 2010    Post subject: Reply with quote
pic 2 is the starter bendix and it has a spring in at our workshop we normally just use spray grease in the bottom bit of it
Walloper
PostPosted: 10:20 - 20 May 2010    Post subject: Reply with quote
Normally an electric motor will use a high temperature lithium grease blend.
But normal grease will do.
Vaseline is only for Lips and Arseholes.
skatefreak
PostPosted: 11:06 - 20 May 2010    Post subject: Reply with quote
Grease it,
good'un, jst going to find out where i was suggeted vasaline haha.
Best regards
-Jvr
The last post was made 16 years, 48 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.69 - MySQL Queries: 13 - Page Size: 58.24 Kb
