derbi gpr starter motor problem
glassman50
PostPosted: 17:58 - 18 May 2010    Post subject: derbi gpr starter motor problem Reply with quote
hi.. i have a derbi gpr 50 2007
everything was fine till last week when my little sister came running into my room and said sam your bikes starting up. and so it was, my keys were in my hand and the starter motor was spinning. how this was i dont know Confused
but all my electrics still wirk but my starter motor, i can hear my relay click when i try it, but nothing else. and like i said, it started with no keys...
any ideas how to fix my starter motor?
ian789
PostPosted: 18:04 - 18 May 2010    Post subject: Reply with quote
You must have the scoot version of KITT.
glassman50
PostPosted: 18:20 - 18 May 2010    Post subject: Reply with quote
explain... Shocked
im 16 and missing my bike Sad
ian789
PostPosted: 18:23 - 18 May 2010    Post subject: Reply with quote
glassman50 wrote:
explain... Shocked
I was joking becuase it does stuff itself Very Happy
Freaky_1
PostPosted: 18:58 - 18 May 2010    Post subject: Reply with quote
unfamiliar with the specific bike, but a common issue of runaway starters is stuck solenoids. Often, once you disconnect the battery to stop the starter running away, the solenoid will be dead and no start.
IF your start solenoid is easy to access, you might try disconnecting the starter lead from it, and placing a test lamp in line.
Frank
mr rip
PostPosted: 20:51 - 18 May 2010    Post subject: Reply with quote
had the same problem with mine after the first time I took it out in the rain
the starter motor was running constantly & burnt out, had the motor, solenoid, & right hand switch gear (for another reason) changed, hasn't done it since
I would suspect your solenoid terminals are touching something & shorting out
never criticise a man until you've walked a mile in his shoes, then when the muck hits the fan you'll be a mile away & you'll have his shoes
glassman50
PostPosted: 21:20 - 18 May 2010    Post subject: Reply with quote
thanks guys
any idea how it could do it without my keys in?
mr rip
PostPosted: 22:50 - 18 May 2010    Post subject: Reply with quote
the solenoid is wired straight to the battery so if it's shorting on something it would turn your motor over regardless of if the keys are in
mine used to do it every time I went over a bump aswell as if I took it out in the rain
mr rip
PostPosted: 22:59 - 18 May 2010    Post subject: Reply with quote
the solenoid is in line to the starter there's no fuse to blow
mr rip
PostPosted: 23:06 - 18 May 2010    Post subject: Reply with quote
I think we're talking cross purposes here
I do mean the relay, I just always call it a solenoid when I'm talking about a starter system
The last post was made 16 years, 127 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 60.81 Kb
