Worth skimming this disc?
PostPosted: 18:45 - 18 May 2010    Post subject: Worth skimming this disc? Reply with quote
It's very close to the runout limit of 0.03mm. (I think the official engineering term is exactly one midges ballhair off at 0.028mm). So it'll get through this MOT but only just.
There is 4.1mm of disc left. The service limit is 3.5mm.
Enough meat there to be bothering with? I'm not sure how much gets taken off when they do a skim?
EDIT: Probably looking at £30-40 for skimming. £230 for new discs.
jimspeed
PostPosted: 19:12 - 18 May 2010    Post subject: Reply with quote
can you not find someone with a big enough lathe?, if it was mine i would turn it so it just scratched the surface off the lowest bit and you do have .6m to play with which to a good bloke is plenty. say take 0.08 in total maybe.
just me and i would do anything to avaoid paying that much for new discs Embarassed
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
bacon
PostPosted: 21:00 - 18 May 2010    Post subject: Re: Worth skimming this disc? Reply with quote
or a "gnats cock" to be more accurate
PostPosted: 21:52 - 18 May 2010    Post subject: Re: Worth skimming this disc? Reply with quote
For the mot - rarely seen them check in that much detail.
Also, often if you hide the limit marking, they won't bother to check.
Gashead Harry
PostPosted: 22:15 - 18 May 2010    Post subject: Reply with quote
Be better off getting it on a ring grinder wouldn't you? Much more accurate and a better finish.
98' Honda CG125W --- 03' Yamaha DT50SM (Gone!) --- 05' (55) Suzuki GS500 K5
steven_191
PostPosted: 22:24 - 18 May 2010    Post subject: Reply with quote
only 2 reasons why i would ever skim a disc
1 - it has a lip that makes installing pads difficult, and then i would only really cut the lip down
2 - i dont like that it has and uneven surface
ive never bothered with number 2
if its close to the limit why take more off?
Walloper
PostPosted: 22:57 - 18 May 2010    Post subject: Reply with quote
I thought a Baw Hair was 0.003"
Never mind a Lathe operators accuracy.
I worked with a Grove crane driver who could lift a 6 ton engine a Baw Hair no problem.
I would pay £30-40 for a skim.
alun111
PostPosted: 23:11 - 18 May 2010    Post subject: Reply with quote
I'd say put it through it's MOT first and if it passes the brake efficiency test and there are no problems leave it (unless you experience negative problems yourself). If it fails then go for a skim..... or possibly better still... look for a s/h disc.
PostPosted: 01:00 - 19 May 2010    Post subject: Reply with quote
I should have phrased that differently.
It'll get through the MOT this time with a small argument as to how significant the slow speed pulsing of the brake lever is on the rolling road. I can categorically state it's within service limits and I know the tester well enough that he'll believe me.
However, it WILL pulse. It did last year and it's worse now. No problem at higher speeds but I really ought to do something about it.
I'l pop it in for a skim and if it lands up too thin, I'll just have to get new ones.
I'm planning to swap the forks and callipers for a VTR front end in the near future so I don't really want to be fitting new pads only to throw them in the bin after a couple of thousand miles when I fit 4-pot callipers (it's a VFR750).
PostPosted: 08:12 - 19 May 2010    Post subject: Reply with quote
Is that VTR as in SP1/2 or fireblade Confused.
PostPosted: 13:36 - 19 May 2010    Post subject: Reply with quote
Firestorm.
PostPosted: 14:03 - 19 May 2010    Post subject: Reply with quote
Erk - well should be a few around as I thought storm owners often tried to swap them for blade ones etc Smile.
PostPosted: 14:37 - 19 May 2010    Post subject: Reply with quote
It has 4-pot opposed callipers. It fits straight in using the original wheel. It has adjustable damping.
The VFR has 2 pot sliding callipers and preload adjustment only.
Fairly common mod for the 750s.
PostPosted: 14:41 - 19 May 2010    Post subject: Reply with quote
If you are going to swap out the front end anyway I would consider the skim.
PostPosted: 14:45 - 19 May 2010    Post subject: Reply with quote
Or a happy medium?
https://cgi.ebay.co.uk/Honda-VFR-750-1992-FN-Front-Discs-1990-1993-FL-FM-FN-FP-/290415230071?cmd=ViewItem&pt=UK_Motorcycle_Parts&hash=item439e18bc77
The last post was made 15 years, 335 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.58 - MySQL Queries: 13 - Page Size: 86.57 Kb
