Please Help Me With My Bike Issue
topto1
PostPosted: 21:00 - 19 May 2010    Post subject: Please Help Me With My Bike Issue Reply with quote
Hey basically i was riding one day and my sport air filter fell off (probably didn’t fit it properly)
The next they i went somewhere without the air filter as i was lazy to put it back on…
It was raining really badly.
Suddenly i noticed my bike getting sluggish and acting up, slowly losing power, i though it was the petrol, so i toped up more but it wasn’t,
I pulled out the petrol station and suddenly i heard a “BANG” i lost all power, it was working but i lost all power, no acceleration, and smoke was coming out off –
https://www.motorcyclenews.com/upload/218333/images/Piaggio_zip.gif ( that little black circle thing near the exhaust )
So i was going home really slowly with no acceleration then after a little while it just shut down on me whilst it was getting slower and slower.
Now when i try to turn it back on i have to electric start it a couple of times, and keep revving very fast until it comes on,
When i full rev it it just shuts down completely, there is no power at all with the bike at the moment,
If anyone can help i would be grateful!.
Model Bike – Piaggio Zip 4 Stroke
neil.
PostPosted: 21:04 - 19 May 2010    Post subject: Reply with quote
Are you saying you ran the engine with NO air filter? If so, it would have sucked in all manner of crap from the air which would almost certainly have caused nasty damage indeed... That and having no air filter means you're probably running lean (too much air not enough fuel).
topto1
PostPosted: 21:06 - 19 May 2010    Post subject: so Reply with quote
So what will i need to do to fix it? or is this a job for the mechanics?
I wanna fix it up and flog it...
Help appreciated thanks
That_Hornet
PostPosted: 21:08 - 19 May 2010    Post subject: Reply with quote
Agreed, put the filter back in and see if it runs properly. Thumbs Up
topto1
PostPosted: 21:08 - 19 May 2010    Post subject: so Reply with quote
topto1
PostPosted: 21:09 - 19 May 2010    Post subject: Already Reply with quote
Already did put the air filter back on, still the same issue Thumbs Down
Paddy Blake
PostPosted: 21:30 - 19 May 2010    Post subject: Reply with quote
Check if there is water in the oil and drain the float bowl.
alun111
PostPosted: 21:44 - 19 May 2010    Post subject: Reply with quote
Same as above. I'd also clean (or preferably replace) the spark plug.
topto1
PostPosted: 21:46 - 19 May 2010    Post subject: Hey Reply with quote
Already did clean spark plug and adjust it,
But u think if i drain the float bowl it will work again,
or maybe its the CDI thats bust?
Heres what the problem looks like...
https://www.youtube.com/watch?v=Px66Z6hV8Fc&feature=player_embedded
ozzy r6
PostPosted: 21:52 - 19 May 2010    Post subject: Reply with quote
i would do a compress test on the engine?
alun111
PostPosted: 21:53 - 19 May 2010    Post subject: Reply with quote
Yer I'd definately start with the small simple jobs first. I'd consider taking the carb off an cleaning the whole thing too.
topto1
PostPosted: 21:54 - 19 May 2010    Post subject: Reply with quote
Ok will do them then post back Smile thanks
mad4it028
PostPosted: 21:58 - 19 May 2010    Post subject: Reply with quote
when you start it in the video i notic the rear wheel didnt turn
plus you said about the smoke near the fan ide start by checking the belt hgasnt snapped and then look more into the smoke
topto1
PostPosted: 21:59 - 19 May 2010    Post subject: Reply with quote
No the wheel does spin! and it even start sometimes! but the acceleration has completely gone and when you go full throttle or even 3/4 it just shuts off....
cb1rocket
PostPosted: 22:21 - 19 May 2010    Post subject: Reply with quote
has it been de-restricted? I had the front variatior nut from the cvt gear system come loose on mind and that was giving no power as the pulley was loose!
Also make sure the cdi has been covered with silicone or similar to close the cut. These are cut open for de-restricting purposes and most people don't bother filling hole after cutting.
Bit off topic but thats what I have had
The last post was made 16 years, 48 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 81.27 Kb
