chain adjustment
jimbojim
PostPosted: 21:19 - 19 May 2010    Post subject: chain adjustment Reply with quote
hi
im new to biking and new to the forum, i have just bought a kinlon 125 but the chain need adjusting its a bit slack, any help would be great thanks
Walloper
PostPosted: 22:32 - 19 May 2010    Post subject: Reply with quote
You really need the exact manufacturer's specification.
But if your stuck I adjust a Honda CG125 to 20mm sag at about the area of the rear tire side wall.
Put the bike on it's centre stand so the rear wheel is free to spin
Slacken the rear spindle/axle bolt till its just finger tight.
Adjust BOTH adjuster slightly Turn one revolution on the left side then one revolution on the right side. This should keep the rear wheel alignment correct. (Assuming it is correct to begin with).
Lift the lower part of the chain up with one finger until you feel resistance. Measure the distance from here to where the chain lies at rest.
Adjust again if needed to get the correct slack.
Tighten the rear spindle bolt again.
dobby
PostPosted: 08:40 - 20 May 2010    Post subject: Reply with quote
you mean to say a chinese bike hasnt self destructed before the chain needed adjusting... well il be dammed Laughing Laughing
anyways about 20/25mm sag in it or if u can understand chinese read the instruction manual Thumbs Up Thumbs Up
Walloper
PostPosted: 10:17 - 20 May 2010    Post subject: Reply with quote
Instluckshions to lemove srack in dlive chain.
jimbojim
PostPosted: 22:03 - 20 May 2010    Post subject: Reply with quote
cheers for that i'll give it a go at the weekend
The last post was made 16 years, 1 day ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 2.56 - MySQL Queries: 13 - Page Size: 43.15 Kb
