Laptop overheats ridiculously fast
5v3d3b0
PostPosted: 19:05 - 20 May 2010    Post subject: Laptop overheats ridiculously fast Reply with quote
Right, a few months ago my laptop started overheating sometimes. Now it's to the point that if I play CS (1.6!!!) for 5 minutes the computer freezes and I have to turn it off with the button... I bought a laptop cooling pad, and that helps a bit, but still 15-20 minutes of CS and it freezes.
With the pad I can do normal surfing and work, but play no games basically. What the fuck is this for quality? I bought it in September!!
Any ideas or solutions?
Frost
PostPosted: 19:30 - 20 May 2010    Post subject: Reply with quote
Make sure it's not overclocked. Make sure that the fan control isn't set manually in the BIOS so that it can't speed up when needed. Put the laptop on a flat surface when using it. When it's turned off go round all the vents with a hoover and try to get some of the dust and hair out of it!
Albion
PostPosted: 22:50 - 20 May 2010    Post subject: Reply with quote
This.
If your resting the laptop on your bed, sofa, soft things that are not flat etc the heat can't escape and it will overheat.
A2 Passed on 07/05/08, CG125 bought on 21/07/08.
The Artist
PostPosted: 23:16 - 20 May 2010    Post subject: Reply with quote
My old laptop overheated a lot, even when balanced on something with plenty of air space underneath.
I took the keyboard out and got to the cpu fan and heat sink and it was packed full of dust and crap. Cleaned it out with a cotton bud and it ran soo much better afterwards.
panrider_uk
PostPosted: 00:43 - 21 May 2010    Post subject: Reply with quote
The fan on my netbook used to run constantly.
I took the plastic mesh out of the air vents and it now runs about 20 degrees cooler.
Mark
Ingah
PostPosted: 02:09 - 21 May 2010    Post subject: Reply with quote
Remove battery, can of compressed air through the all the venting.
Easy, cheap, and might just do the trick.
-- Ingah
Charlie
PostPosted: 08:37 - 21 May 2010    Post subject: Reply with quote
Clean all the venting out, chances are it will be stuffed full of dust and preventing good airflow..
SoND
PostPosted: 18:23 - 21 May 2010    Post subject: Reply with quote
Paste has burnt off overtime.
Remove heatsink, clean with rubbing alcohol and reapply. Blow fins out while you are in there.
temeluchus
PostPosted: 11:55 - 22 May 2010    Post subject: Reply with quote
My HP DV6 did this.
The factories dont use proper thermal compound, they use pre formed pads to make manufacture cheaper. These pads cook rapidly if you run anything intensive like games.
I stripped the lappy, cleaned off the pad, made a spacer from sheet copper to take up the gap and used decent thermal paste.
dextersaurus
PostPosted: 15:41 - 22 May 2010    Post subject: Reply with quote
I got a laptop in that had this problem, thought by some miracle it would be a software problem because it wouldn't do it when sitting in the BIOS, only when the OS was loaded.
But halfway through an XP install it died.
I took the cover off, took the fan off, and the CPU heatink, cleaned them up, put new paste on, sealed them back on again, and had a look at the cooling fan.
N00b mistake on my part as it was clogged up with dust so badly that it wasn't even turning. took out a bit of dust the size of my thumb and popped it back in, worked like a charm.
Compressed air might do the trick but that might just blow it inside the laptop, you'd be better just taking the cover off and cleaning the dust out.
Turn the laptop on, does the fan turn? if not, get it out and turn the fan by hand... should push the dust out.
DON'T blow in it as this could turn the fan too fast, which damages the motor blah blah blah, probably a slim chance of actually breaking it but heyho.
Dunc
5v3d3b0
PostPosted: 00:49 - 23 May 2010    Post subject: Reply with quote
I don't think I'm comfortable taking the fucker apart and applying heat paste and stuff Confused Not really that experienced
I'll try to open it up and get all the dust out
And it's a dv6 Sad
SoND
PostPosted: 11:40 - 23 May 2010    Post subject: Reply with quote
If you can open it up to get the dust out you can do the heat paste too. Cleaning the dust out will be pointless when you find the paste is gone.
Before you start prying and tugging at bits be absolutely sure you haven't missed a screw. Take your time and do it carefully, it shouldn't take force.
The heatsink will be held on with a few screws and a wire. When you remove the screws it may be stuck to the chip a bit because of the paste, twist it and that should break its grip.
A small amount of alcohol and a soft cloth should clean the paste off easy enough with a little scrub. Put a blob the size of a pea on the middle of the chip and screw the heatsink back on.
5v3d3b0
PostPosted: 20:17 - 25 May 2010    Post subject: Reply with quote
Ordered some Arctic Silver 5 off ebay Very Happy
Should arrive tomorrow or thursday, watched a few vids to see how it's done. Only hard thing is disassembling that far
dextersaurus
PostPosted: 21:09 - 25 May 2010    Post subject: Reply with quote
If you take every screw and take pics of whatever of where each screw goes, everything should just clip apart.
I've not worked on many home laptops and the likes, but business laptops are generally pretty easy to work on.
Dunc
5v3d3b0
PostPosted: 00:17 - 27 May 2010    Post subject: Reply with quote
Did it! Took me ages to figure out how to take some things apart, but I got there in the end, and the laptop is now running supercool Very Happy
While I was at it I removed the almost centimeter thick layer of dust from the fan's cooling fins Shocked
Thanks a lot for the help Karma
The last post was made 16 years, 102 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 86.32 Kb
