| pickles |
 pickles Derestricted Danger
| steven_191 |
 steven_191 Nearly there...
| pickles |
| Poseidon |
 Poseidon World Chat Champion
 Posted: 14:22 - 19 May 2010 Post subject: |
Sounds like you've got the same problem I had. My bike is a '94 Triumph Trident, so basically the same 3 cylinder engine. It'd run fine, then suddenly drop bags of power and sound dog rough. Does the rev counter go crazy when the power drop occurs? As that was another symptom of mine.
Turns out it was the ignition coil on the number 1 cylinder. The little metal connector that the low tension cable slides onto was really loose. I found that out by wiggling the wires going into each ignition coils whilst the engine was running and as I wiggled one of them, the problem came and went. I tried fixing the connector, but about a week after "fixing" it, the problem came back again. New ignition coil and it ran sweet as! I seem to think it cost me about £40 for a new one off a German seller on flea-bay. Only one I can find is 2nd hand... CLICKY ____________________ 1977 Honda CG125
2002 Ducati Monster S4 (currently restoring) |
| Bishbash |
 Bishbash World Chat Champion
 Posted: 17:12 - 19 May 2010 Post subject: |
Have you tested the HT leads? Swap a working HT lead off one of the other cylinders with the non working cylinder. Same goes for the coils.
Other than that, as suggested above.  ____________________ My current bikes are - YZF-R1 & GS 500 E
Trackday videos - https://www.youtube.com/user/bishbash13 |
| Ant132 |
 Ant132 World Chat Champion
 Posted: 19:35 - 19 May 2010 Post subject: |
As Poseidon says
A known weak point on these T3 Triumphs are the Ignition coils. They recently started to play up on mine (really noticeable at low revs).
Feel the exhaust downpipes (be careful) briefly or better still, squirt water on them and wait for steam, and see which one is cold(or noticeably cooler than the other two) and then swap the coil from that cylinder to another. See if the problem moves cylinder with the coil movement.
If it does, theres your answer  |
| pickles |
| Ant132 |
| pickles |
 Posted: 21:12 - 20 May 2010 Post subject: |
Thanks Ant123
I drained the carbs and guess what, lots of muck and wait for it,here it comes WATER! Where the hell did that come from. I would say from 3 carb bowls full there was about a tea spoon of water. It runs a treat now and lots of lovely torque. Many thanks to you all for your invaluable help.
Pickles |
| Ant132 |
 Posted: 22:25 - 20 May 2010 Post subject: |
Nice one mate!  |
The last post was made 16 years, 2 days ago. Instead of replying here, would creating a new thread be more useful? |
