What would the symptoms be....
smegballs
PostPosted: 23:02 - 20 May 2010    Post subject: What would the symptoms be.... Reply with quote
of broken/snapped reeds on an Rxs?
The thing died about 3 miles from home, started misfiring then died.
Its got spark, fuel and compression.
When kicked it will sort of half heartedly run but sounds like its firing only just enough to stop stalling and opening the throttle will make it bog and then stall.
As soon as any load is on the engine it stalls.
Crying or Very sad
The Artist
PostPosted: 23:10 - 20 May 2010    Post subject: Reply with quote
So are they broken or not?
If it has spark, fuel and compression and it doesn't run, 99% of the time, it will be that the fuel is not correct for some reason. e.g. mixture.
Check the reeds, while your at it, clean the carb and air filter and put a new plug in.
smegballs
PostPosted: 23:28 - 20 May 2010    Post subject: Reply with quote
Bike is still out by herself, did a carb clean and sparks plug change at the roadside so I'm assuming it's something a little more serious. Sad
Looks like carbs coming off again then to check reeds.
The last post was made 16 years, 1 day ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.85 - MySQL Queries: 13 - Page Size: 35.45 Kb
