Scotoiler ?
voodoo-music
PostPosted: 00:14 - 22 May 2010    Post subject: Scotoiler ? Reply with quote
Could some one please explain what a scotoiler is and what it does
I bought a bike last week with it fitted but i have no idea what it does or how it functions actually where do i find it and what does it look like
cheers
UnspeedySam
PostPosted: 00:16 - 22 May 2010    Post subject: Reply with quote
From what I've heard, they are automatic chain lubrication systems. Saves you having to manually spray on lube all the time. You'll probably find it somewhere near the engine-end of the chain and a tank that you need to fill up with chain lube.
duncanpage
PostPosted: 00:48 - 22 May 2010    Post subject: Reply with quote
The scottoiler is an automatic chain lubrication system.
They were designed to work using the vaccum from the carbs to suck lube onto the chain. You set the flow rate depending on the type of rides you do most often.
The new ones have started using and electric pump i think so that it's not lubricating the chain while you're not moving.
This may have to do with new bikes moving to fuel injection, but I don't know too much about how they work.
You'll find a reservoir somewhere which you must fill and if it's been fitted properly it'll do the rest.
iooi
PostPosted: 07:49 - 22 May 2010    Post subject: Re: Scotoiler ? Reply with quote
Manufacture gives you loads of information about how, what & where......
Very handy piece of kit, but I have found it better to oil the top run of the chain when you only have a single point injector.
Grimnir
PostPosted: 09:23 - 22 May 2010    Post subject: Reply with quote
Massively extends the life of your chain. I ran one when I was a courier, covering ridiculous mileages. The only change I made was to fit an extra reservoir for more oil capacity. Don't bother buying their oil though. Pretty much any oil will do but normal engine oil does not flow too well in the winter. Use thinner oil.
Keep an eye on how well oiled your chain is, and how much splatter gets on your tyre - adjust the flow rate accordingly - do not oil your tyre!
voodoo-music
PostPosted: 09:42 - 22 May 2010    Post subject: Reply with quote
thanks for the info guys
The last post was made 16 years, 155 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 46.91 Kb
