Nsr 125 Backfiring at certain Rpm's
mysterydudes
PostPosted: 12:42 - 22 May 2010    Post subject: Nsr 125 Backfiring at certain Rpm's Reply with quote
Hi there,
i recently bought a 2000 nsr 125 r and ran perfectly untill a few days ago. It started to backfire at around 8000rpm jerking backwards and forwards in all gears including neutral (except jerking), it used to fly past it no problem. Now it is doing the same at around 5000rpm as well. I changed the spark plug, cleaned the filter, adjusted the carburetor mixture but it didnt change the situation. Does anyone know anything i can do, ive seen other posts like this but they seem to be different and this one seems to be getting worse and worse.
Cheers....
L.James
temeluchus
PostPosted: 12:44 - 22 May 2010    Post subject: Reply with quote
Try setting the mixture screw back to factory setting, then drain your float bowl. Possibly water in your carby.
mysterydudes
PostPosted: 14:00 - 22 May 2010    Post subject: Reply with quote
cheers..... ive done them, it seems going past 5000rpm is better now but the 8000rpm problem still exists. Any other suggestions?
thanks
L.James
skatefreak
PostPosted: 14:08 - 22 May 2010    Post subject: Reply with quote
8000rpm is roughly when the powervalve should reach fully open, check it in neutral to see if the servo (under the tank to the right) is moving fully (check back of the cilinder that turns, theres a grove to show full travel).
Long shot but it might have something to do with it.
Is there plenty of smoke when starting from cold?
Engine temp usual?
Maybe give the carb a clean...
Compression test maybehaps, check the condition of the top end...
-Jvr
temeluchus
PostPosted: 15:41 - 22 May 2010    Post subject: Reply with quote
Id try this before anything else, especially since draining the bowl improved things a bit.
mysterydudes
PostPosted: 17:56 - 23 May 2010    Post subject: Reply with quote
I riden to work today and the problem does still exist, it seems when the bike properly warms up it become worse. its becoming unridable as i have to try and keep my revs between 1000-5000 + 6000-8000rpm. I've spotted nothing unusual since i've had it and everything seems fine Confused I'm gona have a tinker with it and see what i can do but i think i might have to book it into a garage... money money money.
Thanks for the advice, have any other ideas?
L.James
temeluchus
PostPosted: 20:16 - 23 May 2010    Post subject: Reply with quote
little point until youve had the carb off.
Worse when warm usually indicates richness. Possibly could be knackered float valve.
alains
PostPosted: 10:59 - 25 May 2010    Post subject: Reply with quote
warm your bike for 5mn then lift your tank on it's stand
start again , watch the pulley on the right and see what it's doing when you accelerate as :
- contact (initialization) LO
- start and idling under 2000 HI
- 2000-7500 LO
- over 7500 HI
tell me the result , does the pulley moves ?
mysterydudes
PostPosted: 18:45 - 29 May 2010    Post subject: Reply with quote
Thanks for the replies, but i took it to a trusted garage and he said its basically scrap..... theres about 500-1000 worth of damage to the engine and other parts. So guess i'm looking for another bike then.
Thanks
L.James
alains
PostPosted: 20:38 - 29 May 2010    Post subject: Reply with quote
why doing so ! just slightly stupid
skatefreak
PostPosted: 21:46 - 29 May 2010    Post subject: Reply with quote
Engine off flea bay - £275-£300...
Really think it would be financially viable to get hands on with this one.
If not,
you selling the bike?
Would be interested in coming up to have a gander.
-Jvr
The last post was made 16 years, 39 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.74 - MySQL Queries: 13 - Page Size: 67.84 Kb
