| binge |
 binge Emo Kiddy
 Posted: 13:47 - 21 May 2010 Post subject: Dellorto PHBH28 Jetting questions: Yamaha TZR125 2RK engine |
Spent the past hour or so trying to jet my Pit bike ready for its track day on the 31st.
Now I started off with a 110 main jet, running quite a skinny carb needle.
It seemed to be running a little too lean, The next size jet I had was a 120.
I've got:
102 : 105 : 110 : 120 : 125 : 135
Now I've also got a slightly fatter carb needle, with more of a taper to it.
I switched to this needle, And fitted the 120 main jet. Thinking the bigger jet will compensate the thicker needle.
It was boggy, and running poor. So I went up to the 125 jet. Still boggy, but ran better.
Upped it to the 135 main jet. And it ran OK. Little bit slow on the throttle response. So I raised the needle to the highest setting (Bottom notch).
It seems to run okay now. Was a bit hard to start at first, But I've screwed the Pilot screw out about 5 or 6 complete turns. (I think on the Delly carb, out = Richer)
It starts with no revs now, Just on the kick start. And revs right through the range without any stutters.
My only problem is. A Stock TZR runs a 26mm carb, with a 180 main Jet.
I am running an open Air filter, A Race exhaust, a 28mm carb. And only a 135 main jet.
The plug has started to brown/black up on the electrode only. But I can really ride it too far as it's not road registered any more.
How obvious will the plug colour be after only maybe 30 or 40 seconds of full throttle riding. I can get it right up through the gearbox into 5th or 6th gear easily in this time.
Will this be giving me a good indication to how it's running?
Also wanted to mention, I'm also running it on 30:1 premix. But once it's run in a bit, I'm going to up it to 40:1 premix.
Ben |
| binge |
 binge Emo Kiddy
| stirlinggaz |
 stirlinggaz World Chat Champion
| binge |
 binge Emo Kiddy
| binge |
 binge Emo Kiddy
 Posted: 16:52 - 21 May 2010 Post subject: |
| stirlinggaz |
| binge |
 binge Emo Kiddy
| binge |
 binge Emo Kiddy
| stirlinggaz |
 Posted: 12:58 - 22 May 2010 Post subject: |
hi,
i dont think i understood you properly....
you have a phbh carb, with pretty much standard jets,right?
but you have swapped the needle for a visibly thicker one, yes?
where did this needle come from, as the needles in rs125's carbs are all very similar to the naked eye.
so if its bigger/thicker its not standard & the jetting wont suit it, if im getting this right.
its not just the thickness thats different, iirc there are about 6 different dimensions on a needle, the taper, tip diameter,shank lenth & diameter etc.
seriously have a look at how many different needles are available from dellorto,lol & you'll see what i mean.
have you had a chance to get a magnifying glass on the needle? is it a K type? X type?
i think the needle makes a big difference to the whole set up.
EDIT : have a look at this & you will see what i mean https://www.dellorto.co.uk/editor/uploads/images/X-W%20Needle%20charts.pdf
cheers,
GAZ
| binge |
 binge Emo Kiddy
 Posted: 13:14 - 22 May 2010 Post subject: |
Yes, the needle came from another RS125 carb.
I've got 2 complete Dellorto carbs.
Ones is a PHBH28RD, And the other is a PHBH28BD.
The thicker needle came from the BD. I was running the RD on the bike.
I've now changed to the other carb, The BD. It's got a slightly different pilot jet arrangement.
But this carb came off a 125cc RS125, Which was bog standard. So it's the stock carb, Stock needle, Stock jet.
I cant remember what jet was in it when I got it, As I've changed it now.
I'm currently running the PHBH28BD, with the needle on one notch from the top.
135 Main jet. Pilot screw (Which is not in the same place on both carbs), set to about 2 turns out.
Seems to run OK now. Although it is a bit boggey low RPM.
When I open it up fully, Then close the throttle, On over run, it sounds/feels like it's cutting out. Then when I get back on the revs, I can be a bit snatchy.
But it will rev right out almost, without bogging down. Very high RPM it splutters a bit.
Strange...
I hate carbs!  |
| binge |
 binge Emo Kiddy
| stirlinggaz |
 Posted: 13:28 - 22 May 2010 Post subject: |
i editid my post, not realising you had replied,
take a look at the needle charts & you will see there are other characteristics to be taken into consideration when changing needles, not just lenth & diameter https://www.dellorto.co.uk/editor/uploads/images/X-W%20Needle%20charts.pdf
i'd try & identify which series of needle it is 1st,
the BD is off rs125, iirc & the RD is off a mito? or is it the other way about? lol. anyway, could you list the other jets & emulsion tube numbers, that would help a great deal.
cheers,
GAZ |
| Kickstart |
 Kickstart The Oracle
 Posted: 13:35 - 22 May 2010 Post subject: |
There are loads of different needles used in Dellorto carbs.
The needle will make next to no difference to full throttle mixture, while the main jet will make next to no difference to anything other that full throttle.
The slimmer needle will give a richer mixture from about 1/4 to about 3/4 throttle. Below that the mixture screw and the shape of the carb slide control the mixture. Above it the main jet is the important factor.
The mixture screw can be either an idle air screw (undo to allow more air through, so anticlockwise = leaner) or an idle mixture screw (undo to allow more fuel through, so anticlockwise = richer). Looks like you have one carb of each type. If the mixture screw is nearest the engine then it is a mixture screw, if it is on the airbox side of the carb then it is an air adjustment screw.
Mikuni and Dellorto jet sizes are not comparable (and Mikuni have used different methods to size them).
Personally, ignore the needle for now. Find a steep hill and do a few plug chops, making sure you are on full throttle, to get the main jet right. Once that is done play around with the needle(s) to get it to work on normal throttle openings, and then play with the mixture screw.
Basic guide to dellorto carbs here:-
https://www.bikechatforums.com/viewtopic.php?t=17124
| binge |
 binge Emo Kiddy
| binge |
 binge Emo Kiddy
 Posted: 14:19 - 22 May 2010 Post subject: |
Okay, I think I may have made a little fuck up too.
The two spouts on either side of the carb. What do these do?
I thought they were some sort of overflow spouts!
So I've piped them into an overflow catch bottle, Which could well be restricting air getting into them if they are what I think they are....  |
| binge |
 binge Emo Kiddy
 Posted: 16:32 - 22 May 2010 Post subject: |
Inspecting both carbs now.
Carb bodies differ slightly.
One is a BD carb, Which has a Fuel Mixture screw. Inside the float bowl area, It has only one jet in the top left hand corner as you look at it upside down.
The other is an RD Carb. It's got an Air Bypass screw. and it has two jets in the top left hand corner when you look at it from the underside with the float bowl off.
Carb sliders, I have two. they both fit in both carbs. One has 50 written on the underside of it, The other has 55 written on the underside of it.
I have 2 Carb needles. The thicker of the two has X1 25 written on it.
The thinner of the two has X56 written on it.
2 Jet holders which appear to be identical.
Now the jets in the bottom of the carb. I am not sure which are called which.
Both carbs have a small jet just beneath the Main jet. I cant get one of them out, It's stuck in situ.
The other has a 5.5 in there.
Jets in the top left hand corner. Both have the same bigger jet, Which are 70.
Only one of the carbs have a smaller one in the corner, The other has nothing there.
The smaller one has 90 written on it.
All confusing stuff ay.
I'm going to assemble a carb using the better of the two bodies. And go from there. If it comes to it, I think I'll just drop it off at a 2t tuners place and let them do it all for me. |
| Kickstart |
| binge |
 binge Emo Kiddy
| binge |
 binge Emo Kiddy
| Kickstart |
 Posted: 17:09 - 22 May 2010 Post subject: |
It is a slide carb. It won't work properly if you just give it full throttle at low revs. You are opening it up to run on the main jet yet there is stuff all pressure drop through the venturi to draw fuel from the float bowl.
Coping with full throttle from low rpm is why CV carbs became popular. They could ignore rider abuse like that
Moving the clip on the needle makes it richer / leaner. Clip closer to the sharp end makes it richer. You choose a needle with the right shape to move from lean to rich by the amount you need, and then use the clip to make it richer or leaner overall.
| binge |
 binge Emo Kiddy
| stirlinggaz |
| binge |
 binge Emo Kiddy
| stevo as b4 |
 Posted: 23:06 - 23 May 2010 Post subject: |
Feel your pain Binge!
I've had enough trouble myself trying to set up bigger or different carbs on tuned 2stroke scooter's/bikes before.
I do agree that with a fresh plug and some common sense guess work that it's possible to get the main jet somewhere close at the least. The idle can be sorted the next easiest, but playing with th pilot screm is only a very fine adjustment, and normally the pilot jet needs changing for a given carb to suit another engine.
The midrange is where it's really hard to get a decent fueling slope throughout the rev range under all load conditions. The other thing to remember is the fact that there's alot of overlap between jetting circuits, and if you get say the main jet about right, but that the midrange is way too rich, then you can end up correcting the midrange fueling, but then you go too lean again at the top.
TBH with a brand new or re-built engine i would get it running okayish on the main jet if a bit rich, and then take it to an experience dyno tuning centre, one of the ones that is still experienced with carb tuning. This way at least they can run the bike in a controlled enviroment and log the AFR at different loads and through the rev range. It costs a bit to have a bike dyno set up, but im too worried about blowing up or seizing engine's to experiment with jetting a bike properly which unless you have a lot of experience with, is very hard to get your head around and get a decent result quickly. |
| Crafty |
 Crafty Derestricted Danger
 Posted: 11:52 - 24 May 2010 Post subject: |
Hi there,
I've had similar issues with a 21mm PBHG on my sons Suzuki TS50X. With hind sight I should have just bought a brand new standard 12mm mikuni but it was a lot more to buy
Heres what I found AFTER FINALLY using a dynamometer
Air jet & air screw control 0-1/4 openings (any carb)
Needle controls 1/4-3/4 openings (fatter = less fuel, thinner = more fuel) circlip raised to top leans mixture & lowered richens it
The needle restricts flow from the main jet thats all it does (as in any carb)
Main jet controls 3/4- full openings (also any carb)
I have spent weeks making calls & sending emails to various top tuning experts over in the States as well as here at home (karting as well as bikes) & the general talk is that these are excellent when set up correctly, but to set them is just about impossible without using either a dyno, or an air fuel analyser due to the MILLIONS of combinations there are for them. (so thats why the top guys use them then me thinks)
These carbs also seem to work completely opposite to a Mikuni in there readings using logic, even the plug chop gave same sort of results your getting ie black.
My air screw is set at 3 & 3/4 out for instance, not 1-1 1/4 as a mikuni
First of all you need to check the atomizer (Main jet screws into this) is an "AU" & NOT an "AN" TYPE
AU is for 2 strokes, AN is for 4 strokes
AN types are full of holes & mess up low & mid range on 2 strokes so you'll never get your setup right if your running an AN.
GETTING CORRECT MAIN JET ONLY GIVES CORRECT MIX @ 3/4+ OPENINGS
Its a bar room myth that holed pistons ONLY HAPPEN @ FULL THROTTLE.
Holed pistons can happen at tick over if run long enough with weak mixture, likewise with any throttle position/weak mixture. Thats why,
IT'S VITAL TO GET THEM SET UP @ ALL THROTTLE OPENINGS
When it's sorted you will get INSTANT response from any throttle opening i.e. No lag or hesitancy
I hope this helps you out but I can say thay £50# a session for dyno was money well spent in the long run.  ____________________ To FINNISH 1ST, 1ST you gotta FINNISH.
Fastest is the 1ST to CROSS the FINNISH LINE.
2ND, IS the 1ST of all the LOSERS. |
The last post was made 16 years, 113 days ago. Instead of replying here, would creating a new thread be more useful? |
