FFS!. Servicing the bike, bolt snapped.
m0l0t0v
PostPosted: 17:27 - 22 May 2010    Post subject: FFS!. Servicing the bike, bolt snapped. Reply with quote
No, not the oil sump bolt.
It's another bolt that oil drain from as well.
It's a '92 Kawasaki GT550.
I was taking the generator cover off as the gasket as leaking and I was putting a new one in since I was changing oil, filter, air filter and spark plugs.
Well I though this bolt was part of the cover (Rolling Eyes), then found out it wasn't when I took it out. Then putting it back in I didn't even do it up hard, was not far off from being hand tightened and the fucker broke on me.
Anyone enlighten me to which bolt it is please?
https://sphotos.ak.fbcdn.net/hphotos-ak-ash1/hs521.ash1/30651_389401826614_509016614_4622003_3994899_n.jpg
https://sphotos.ak.fbcdn.net/hphotos-ak-snc3/hs561.snc3/30651_389401836614_509016614_4622004_4366963_n.jpg
https://sphotos.ak.fbcdn.net/hphotos-ak-snc3/hs561.snc3/30651_389401846614_509016614_4622005_5420949_n.jpg
https://sphotos.ak.fbcdn.net/hphotos-ak-sjc1/hs581.snc3/30651_389401851614_509016614_4622006_7358551_n.jpg
And how would I get the fucker out?!
Mad
Blackwolf
Burgerfist
PostPosted: 17:32 - 22 May 2010    Post subject: Reply with quote
As for getting it out you may be able to get a Torx in there and/or heat/ freeze and release?
No idea what it is though. Laughing
TUG
PostPosted: 17:47 - 22 May 2010    Post subject: Reply with quote
Omfg what did you do? Swing on it? You need to left hand thread it for ease but because of the nature of the bolt i don't know how much swarf will enter the engine unless you grease it up like mad and fish it all out.
Haz ER-5, innit!
m0l0t0v
PostPosted: 17:55 - 22 May 2010    Post subject: Reply with quote
Hardly. Did it up hand tight, then grabbed my socket wrench and I barely put any force on it and the fuck broke.
Left hand thread it? I have no idea what you jut said Laughing
Watdafukhappe... This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
MaybeGuy
PostPosted: 18:03 - 22 May 2010    Post subject: Reply with quote
this is probably one of the only times when considering using an easy out may be a good idea.
how big is the hole?
TUG
PostPosted: 20:25 - 22 May 2010    Post subject: Reply with quote
Matts right, its going to be a right ball ache getting that out, if you can try to get hold of one of them.
Haz ER-5, innit!
binge
Emo Kiddy
PostPosted: 20:27 - 22 May 2010    Post subject: Reply with quote
Looks to me like a hollow bolt.
It will be piece of piss to get out, if it's snapped while going in.
The head of the bolt is now broken off, so there is no pressure on the remains of the bolt.
An easy out will go in there no problem.
Ben
skatefreak
PostPosted: 20:35 - 22 May 2010    Post subject: Reply with quote
Screwdriver (maybe 4/6 point star), few taps with a hammer and may just screw out?
Ps, may not work, have no clue, just a thought haha!
-Jvr
Nemo
PostPosted: 22:05 - 22 May 2010    Post subject: Reply with quote
LOL first the exhaust now the bolt that does whatever, what's this bike going to throw at you next?!?!?!
As for getting that out, I reckon the screwdriver thing'll work, it can't be that tight in there
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
Alexio
PostPosted: 22:30 - 22 May 2010    Post subject: Reply with quote
I would try getting it out with a screw driver and a hammer probably.
ZRX61
Victor Meldrew
PostPosted: 23:21 - 22 May 2010    Post subject: Reply with quote
It's the plug for the main oil gallery.
m0l0t0v
PostPosted: 00:59 - 23 May 2010    Post subject: Reply with quote
Guess I'll be replacing the o ring around it too. Laughing
Ah fuck it.
I'm gonna google easy out, whatever the fuck that is. I'll try the flat head + hammer, but slightly worried about damaging the thread...
m0l0t0v
PostPosted: 01:02 - 23 May 2010    Post subject: Reply with quote
https://cgi.ebay.co.uk/12-PC-BROKEN-SCREW-EXTRACTOR-SET-STUD-REMOVER-EASY-OUTS-/230464242487?cmd=ViewItem&pt=UK_Hand_Tools_Equipment&hash=item35a8bd4337
Something like this?
So would be using the drill bit to drill a thread in the bolt and screwing in the thing till it tightens up and then untwist the easy out thing with the bolt?
Edit: Just read the "how to" part Rolling Eyes
Will try flat head and hammer tomorrow, if that doesn't work I'll use the easy out thing Thumbs Up
Ta people Thumbs Up
Also, will start looking for the bolt now, how the fuck am I supposed to find one?!
el_oso
PostPosted: 03:36 - 23 May 2010    Post subject: Reply with quote
that shouldn't be that hard to get out. should be able to turn it by hand. i think i used a small flat bladed screwdriver to get one of the things out before.
i also glued the bolt back together with some araldite.
Duke 390
Car: Jeep Wrangler 4.0L
PostPosted: 09:41 - 23 May 2010    Post subject: Re: FFS!. Servicing the bike, bolt snapped. Reply with quote
First off, I'd look on a microfiche and see exactly what it does - it looks like some kind of drain bolt or similar.
If you don't particularly expect to need to use it, you could consider just sticking some chemical metal over it.
PostPosted: 09:51 - 23 May 2010    Post subject: Reply with quote
Located that low down on the engine, it's got to be a drain bolt.
m0l0t0v
PostPosted: 12:03 - 23 May 2010    Post subject: Re: FFS!. Servicing the bike, bolt snapped. Reply with quote
I did think of that... But not sure if I should do it or not...
Where can I find a microfiche for it? I've tried searching...
Billing
PostPosted: 12:11 - 23 May 2010    Post subject: Reply with quote
try cmsnl, look under the z550 (I was led to believe these 2 shared a common engine)
I've looked at a quick pic of the crank case on there, it looks like you need part number 920661096, available @ 5.50 euro Smile
double check that here ----> https://www.cmsnl.com/kawasaki-1992-g8-z550_model12603/partslist/E1411.html
m0l0t0v
PostPosted: 12:21 - 23 May 2010    Post subject: Reply with quote
I'm pretty sure that they do Thumbs Up Thanks.
Now to try and find it here...
ZRX61
Victor Meldrew
PostPosted: 17:14 - 23 May 2010    Post subject: Reply with quote
As already stated, it is NOT a drain bolt, it's the main oil gallery plug. There's likely an identical one on the other side of the engine....
m0l0t0v
PostPosted: 17:16 - 23 May 2010    Post subject: Reply with quote
Yeah when I looked inside I did see another one...
m0l0t0v
PostPosted: 23:09 - 24 May 2010    Post subject: Reply with quote
Got the bolt out. Piss easy job. Didn't even need a hammer. Just uses a flat head screwdriver, sort of wedged it inside and twisted anti-clockwise. Took 10 seconds Laughing
Will be going round breakers/salvagers tomorrow. Praying
m0l0t0v
PostPosted: 23:18 - 24 May 2010    Post subject: Reply with quote
I hope I find one. A friend has an ER5 that isn't doing anything so if it fits I can nick it from that. Very Happy
I really want to ride the bike tomorrow so I can get some wheelie shots Cool
Air filter changed, spark plugs changed, oil filter changed... oil waiting to get in... Generator gasket done...
The last post was made 16 years, 81 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.43 - MySQL Queries: 13 - Page Size: 135.71 Kb
