can anyone please help ( running rich )
dem0n0
PostPosted: 09:16 - 23 May 2010    Post subject: can anyone please help ( running rich ) Reply with quote
hi i have a hyosung gt125r with a scorpion end can but at reduced speeds it make a popping noise is this normal or is it running lean can the carbs be adjusted do they need to be , i also have a new set of plugs but have not fitted them yet .
WetSparks
PostPosted: 10:17 - 23 May 2010    Post subject: Reply with quote
If the popping is happening under deceleration, it is possible that you have an air leak between the carb and the inlet manifold. OTOH if its when you are just pootling along it could be that your running a little too rich. Have you checked the colour of your plug Question
PostPosted: 10:25 - 23 May 2010    Post subject: Reply with quote
by reduced speeds, do you mean when you roll off the throttle and let it do engine braking.
My scorpion canned GT125 did that, has it still got the baffle in?
Carbs dont need to be adjusted for a scorpion can Thumbs Up
You can fit the new plugs...they are a pig to get at, take the tank off etc, best to have a friend to hold it up as the mounts just fall off Laughing
If the spark plug is real black, its rich, if its a nice coffe/tan colour you are fine, if its white check your bank account for a carb setup/new bike Laughing
Should be fine though...my bike was ace with a scorpion, except mine had an air filter + rejet and it popped when you let go of the throttle and it got to 5000rpm
dem0n0
PostPosted: 11:25 - 23 May 2010    Post subject: Reply with quote
ok thanks i have just bought some irridium plugs so i will put them in next week if it is running rich what do i do it only pops when i roll off throttle like you said ,thanks for replies.
PostPosted: 11:27 - 23 May 2010    Post subject: Reply with quote
just leave it, it will be fine.
you are aware you wont see any difference with iridium plugs right?
dem0n0
PostPosted: 11:42 - 23 May 2010    Post subject: Reply with quote
yeah they just seem to be better quality from what i have heard i have to use it every day so i opted for what i considered to be the best .
its already cost me a arm and a leg as i bought it as a cat c , ive started a trend i might as well carry on lol.
PostPosted: 18:15 - 23 May 2010    Post subject: Reply with quote
fair enough Smile
cat c... thats a shame, but hey if its cheap, its cheap!!!
Crafty
PostPosted: 19:46 - 25 May 2010    Post subject: Reply with quote
Actually it makes a very small improvement to mpg & on a 2 stroke they last at least twice as long, & often even 3 times longer than standard plugs. I used to use platinum plugs (forerunner of iridium) on my TS50ER, then I tried them on my X7 (1000 miles from standard plugs) 5000 from platinum, then on my RG250 gamma mk1 & finally I USED THEM ON MY RG500 GAMMA. All these bikes were purchased new & all improved to a degree that at least equalled the added cost involved. I fitted iridium to my sons bike & he has also noticed a small improvement over standard plugs performance & fuel economy, longer life to be confirmed as of yet, but I fully expect that too.
The spark is much stronger giving a much better fuel/air burn making marginal improvements in performance too, we're talking acceleration here, not top speed & its very marginal too. A bit like using super unleaded only less. The smaller the bike the more noticable it is too. Shocked
If it makes no difference perhaps you can explain why Mitsubushi choose to fit Iridium Spark Plugs as standard equipment to the EVO?
To FINNISH 1ST, 1ST you gotta FINNISH.
Fastest is the 1ST to CROSS the FINNISH LINE.
2ND, IS the 1ST of all the LOSERS.
The last post was made 16 years, 110 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 58.06 Kb
