1987 Kawasaki KH125
wigat1
PostPosted: 13:22 - 23 May 2010    Post subject: 1987 Kawasaki KH125 Reply with quote
Any help with the following would be greatly appriciated
6 volt system
Only electrics that work when ignition is on
Horn
Indicator relay clicks(But no indicators light up)
Neutral light doesn't even come on
have test lights etc individually with a spare battery and they all work fine
Any ideas?????
finpos
PostPosted: 17:57 - 23 May 2010    Post subject: Reply with quote
The answer is probably "it's supposed to be like that", lots of small bikes have 3 electrical circuits, one runs the ignition, one runs off the battery (usually indicators, horn etc) and the final one runs the lights straight off the alternator, so no running engine = no lights.
If the battery circuit stuff is not running right, you most likely need a new battery. They tend to be cheap and not last too long.
f.
PostPosted: 18:21 - 23 May 2010    Post subject: Reply with quote
i happen to own the same bike Very Happy
key on gives me neutral light, horn doesnt work as battery has snuffed it, all the lights are very dim.
Kick it over you have headlights, rear lights, horn etc.
My indicators are hit and miss.
The rear brake switch is notorious for sticking, so check that out.
But in regards to this, is the bike running when you try the lights etc?
The last post was made 16 years, 121 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.35 - MySQL Queries: 13 - Page Size: 34.85 Kb
