| JonE |
 JonE Scooby Slapper
 Posted: 20:37 - 22 May 2010 Post subject: |
| JonE |
 JonE Scooby Slapper
 Posted: 20:48 - 22 May 2010 Post subject: |
If it is the main cover then it holds the oil for the gearbox and covers the clutch. You probably could get away with a cornflakes box gasket and being a 2 stroke there are no oil passages to get blocked if you over used instant gasket. However I would be tempted to use some gasket paper (try some old dodgy looking motor factors) and then use them without gasket goo (although probably grease them before use).
| JonE |
 JonE Scooby Slapper
| JonE |
 JonE Scooby Slapper
 Posted: 21:09 - 22 May 2010 Post subject: |
Thanks Keith
I'll see what they've got and go for the closest to corn flakes packet thickness
All I've got to do now is find time to do it, I also need to check the drain plug when I've got it out as that is leaking a bit but I'm hoping it's just the copper washer that needs replacing. Hopefully that will sort the leaks but I've also got signs of oil on the very bottom where the crankcases join but I've got my fingers crossed that the oil is finding it's way there from one of the other leaks, if not it will mean engine out to split and reseal them which I think would be too big a job and too time consuming for me.
Cheers
Jon |
| steven_191 |
 steven_191 Nearly there...
| JonE |
 JonE Scooby Slapper
| hondapartsman |
 hondapartsman Renault 5 Driver
| JonE |
 JonE Scooby Slapper
 Posted: 10:53 - 24 May 2010 Post subject: |
I've never had a cornflakes packet gasket leak, had a few proper gasket paper ones do so.
The big ones can be a hassle to cut out though so I wouldn't blame you for buying them.
The timing cover, rocker covers, oil pump end caps and oil filter chamber on my Bullet all have cereal packet gaskets.
Kats CB500 has them under both the clutch and alternator cover.
I suspect as long as there is a gasket of some sort in there, it'll be fine. Especially on a stroker where the oil isn't under pressure. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Walloper |
 Walloper Super Spammer
| chris-red |
| JonE |
 JonE Scooby Slapper
The last post was made 16 years, 113 days ago. Instead of replying here, would creating a new thread be more useful? |
