rs125 idle problems!!!!!!!!!
lbarrett
PostPosted: 10:50 - 15 May 2010    Post subject: rs125 idle problems!!!!!!!!! Reply with quote
hi, just got my rs running again starts first time and idles well to 60 then i take the choke off and it revs really high to like 7000 rpm????
stirlinggaz
PostPosted: 13:56 - 15 May 2010    Post subject: Reply with quote
throttle cable stuck? with the engine off, try opening the throttle right up & letting it go.
can you hear the carb slide clunk down? if not, then its caught somewhere, like to be at top of carb.
or air leak at carb manifold (prone to splitting)
have you tried the idle adjust screw?
oh, & why are you letting it idle to 60 degrees?
cheers,
GAZ
lbarrett
PostPosted: 13:26 - 16 May 2010    Post subject: Reply with quote
hi, can hear carb slide clunk down... now it starts then just looses power n cuts out...?
always thought u had to warm the bike up b4 use.
stirlinggaz
PostPosted: 20:28 - 16 May 2010    Post subject: Reply with quote
yes, you need to warm it up, but dont let it idle for ages as it fouls plugs, which you may well have done!
stick a new plug in, start it up & as soon as "COLD" turns to a figure, then you can set off, just take it easy till its up over 50deg, then you can start thrashing it.
cheers,
GAZ
lbarrett
PostPosted: 21:11 - 23 May 2010    Post subject: Reply with quote
but it still sudnt cut out after starting it??? it dosnt wanna idle which it did b4... cheers
steven_191
PostPosted: 22:07 - 23 May 2010    Post subject: Reply with quote
once its started up open the throttle slightly so its at fast idle. effectively doing the job of the choke. see if that sorts it out after a few minutes. if not then id suggest cleaning out the carb, setting it up again and check your fuel supplys not blocked. check the plug is ok. you can clean it up with a wire brush or drag a sheet of fine sand paper through the gap a few times. just to give it a clean bit of metal. check the gap too if you can
lbarrett
PostPosted: 17:35 - 26 May 2010    Post subject: Reply with quote
its seems to idle alright now... but wen i go to put it into gear it cuts out??
Crafty
PostPosted: 19:40 - 26 May 2010    Post subject: Reply with quote
The clutch is dragging then Confused It's probably nothing to worry about. most likely the oil viscosity is too thick (unless you've adjusted the clutch or cable) it should be no more than S.A.E.10/40 or even S.A.E. 5/30 check with your dealer for confirmation of correct gearbox oil, or your owners manual. It will run on S.A.E. 20/50 though
Pull in clutch lever, blip the throttle to 3-4000 rpm & then engage gear. If it still cuts out then clutch needs adjusting. If it keeps running then its definitely oil viscosity causing the clutch plates to drag. Wink
To FINNISH 1ST, 1ST you gotta FINNISH.
Fastest is the 1ST to CROSS the FINNISH LINE.
2ND, IS the 1ST of all the LOSERS.
stirlinggaz
PostPosted: 21:49 - 26 May 2010    Post subject: Reply with quote
75W/90 is the recommended gear oil, though most folks just use rockoil lite gear oil,
either change the oil or adjust the clutch cable using the special clutch tool or 12mm socket from 1/4 set & hold it with molegrips & loosen the grub screw with a screwdriver through the middle of the socket.
also check the side stand switch circuit, these do have a habit of failing.
cheers,
GAZ
The last post was made 16 years, 106 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 60.11 Kb
