| DogHeadGod |
 DogHeadGod Traffic Copper
 Posted: 20:06 - 24 May 2010 Post subject: Knock/Click Type Noise |
Hey guys, I'm hoping somebody can give me an idea here about what can be causing this....
My bike ('05 plate ZX6R 636) is making a loud knocking/click sound when accelerating.
The click speeds up as the bike speeds up, roughly 1 click per second at 5-10mph then increasing.
Today in an effort to solve it I have lubed and adjusted the tension on the chain and I had a mate look for tight spots on the chain as I rolled the bike forward.
I had the rear wheel off the ground with a paddock stand and spinning it by hand there is no noise, i also tried running the bike in gear while it was off the ground and it doesn't do it then either.
I changed the front brake pads which were worn out, after a local mechanic said that may be the source of the noise, but no dice.
If you hold the throttle steady or ease it off the noise stops.
All the cables I can see are secure, so I don't think it is any of those.
The bike feels ok, acceleration is normal, there are no weird vibrations in the handlebars, pedals or levers
Given the fact that it is around 1 click per second at 10mph I don't *think* it is the engine, as I reckon anything in there would be much faster, the same for the wheels/wheelbearings.
Oil, coolant and brake fluid levels are all good.
I've ran out of ideas, and am now just hoping it's not going to be an expensive fix... so any suggestions will be much appreciated.
Cheers! |
| neil. |
 neil. World Chat Champion
| DogHeadGod |
| That_Hornet |
 That_Hornet World Chat Champion
 Posted: 21:40 - 24 May 2010 Post subject: |
Have a little look at your calipers on your way aswell. Mine move side to side when I ride.  |
| Phoenix |
 Phoenix Twisted Firestarter
| Walloper |
 Walloper Super Spammer
| Damon |
 Damon World Chat Champion
| MarkJ |
 MarkJ World Chat Champion
| DogHeadGod |
| Maruchino |
 Maruchino Spanner Monkey
| DogHeadGod |
 Posted: 21:42 - 03 Jun 2010 Post subject: |
New front tyre on it today and new wheel bearings. Still clicking though.
Mechanic couldn't find the problem and recommended a new chain and sprockets as the next step.
If that doesn't resolve it he reckons its the gearbox  |
| Pete. |
 Pete. Super Spammer
 Posted: 21:48 - 03 Jun 2010 Post subject: |
I have had this noise before. In my case it turned out to be the spacer tube in the wheel between the two bearings. The bearings weren't quite snugged up to the spacer and every time the wheel turned the spacer would 'fall' onto the spindle with an audible tick. ____________________ a.k.a 'Geri'
| DogHeadGod |
| Pete. |
 Pete. Super Spammer
The last post was made 16 years, 142 days ago. Instead of replying here, would creating a new thread be more useful? |
