how to restrict a bike?
stirlinggaz
PostPosted: 14:31 - 25 May 2010    Post subject: how to restrict a bike? Reply with quote
hi all,
mate of mine has got a little trail bike for his 10yr old son., think its a yamaha yz90.
anyway, he reckons its a bit fast for a 1st bike, so we are wondering what would be the best way to restrict it?
i was thinking of some kind of throttle stop?
anyone any ideas?
cheers,
GAZ
PostPosted: 14:38 - 25 May 2010    Post subject: Reply with quote
A slice of plastic water pipe on top of the throttle slide which prevents it opening fully is one I've heard of before.
Crafty
PostPosted: 15:29 - 25 May 2010    Post subject: Reply with quote
Ditto
but make sure its suitable with petroleum based chemicals Rolling Eyes otherwise it could melt causing all sorts of problems.
Or better still, do same using washers but measure the slides bore & the OUTSIDE DIAMETER of the washers to ensure they will fit. This mean you can easily (see *top tip* below) add to, or remove some/all, to suit your sons needs as his ability grows.
*TOP TIP*
Whatever method you choose make sure you cut a small slot in them wide enough to slide the throttle cable through, so you can feed the throttle cable into the centres without the need to remove/refit the slide from the throttle cable. It can be a real pain in the 4RS3 otherwise & very time consuming too Wink
To FINNISH 1ST, 1ST you gotta FINNISH.
Fastest is the 1ST to CROSS the FINNISH LINE.
2ND, IS the 1ST of all the LOSERS.
The last post was made 16 years, 110 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 36.62 Kb
