Cut's out on low revs? any help?
cheets650
PostPosted: 20:46 - 25 May 2010    Post subject: Cut's out on low revs? any help? Reply with quote
Hi all,
My SV650 curvey (W) is playing up and i'm looking for a little help.
Had an off at xmas so the bike stood still for a couple of months. Got back on and thought it just needed a good out. However the problem still exists - as the sv is my commuter and I do about 40 miles a day.
Basically to keep the bike running I need to keep the choke on - when I close the choke at revs drop below 2k it cuts out. Twice when on the M1 at 70 mph I have felt the bike splutter and a load of white smoke shot out (don't know if it's connected).
Thanks in advance.
John
iooi
PostPosted: 21:12 - 25 May 2010    Post subject: Reply with quote
Sounds like something in the carbs is damaged. Might be a float that is stuck.
Might be worth taking the tank off and checking the air box, thats if its under the tank... No idea on a Sv.
Having to run with the choke on, would indicate weak running. But could also be a problem with the fuel supply to the carbs.
cb1rocket
PostPosted: 21:27 - 25 May 2010    Post subject: Reply with quote
check the tank vent for blockages
as for the white smoke = oil burining (although it can be blue mostly)
or a coolant loss ie headgasket.
check your oil level and fuel tank and go from there
check the coolant is still visible in the expansion bottle as well
cheets650
PostPosted: 18:16 - 26 May 2010    Post subject: Reply with quote
Many thanks for the pointers - I'll take a good look over the weekend.
The last post was made 16 years, 109 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 39.52 Kb
