| Chris750 |
 Chris750 Brolly Dolly
| Paxovasa |
 Paxovasa World Chat Champion
 Posted: 10:46 - 26 May 2010 Post subject: |
I suggest you take the caliper off, remove the pads, move the pistons out and give them a clean (brake cleaner or WD40) dont get WD40 on the discs or pads.
Push the pistons back in and replace pads (if pads are shiney then give then a gentle rub on a paving flag to get the shine off) then reattach the caliper(s).
Copied from this thread: https://www.bikechatforums.com/viewtopic.php?p=2505523#2505523 ____________________ Suzuki GSF600 K3 (in the fastest colour, black). |
| WetSparks |
 WetSparks Renault 5 Driver
 Posted: 10:50 - 26 May 2010 Post subject: |
Disk pads are normally free floating with no adjustment screws. The screws you can see are probably to secure the sliding pins that the pads sit on. It may well be that an accumulation of brake dust and road crap is causing the pads to stick a little rather than floating free. Just remove the pads and clean everything up to get it running nice and free again.
Morning John  |
| MarJay |
 MarJay But it's British!
| DrDonnyBrago |
| gmanxiii |
 gmanxiii World Chat Champion
| Chris750 |
 Posted: 14:40 - 26 May 2010 Post subject: |
Thanks for the replies.
If its not an easy fix I will leave for now as its hardly noticable.
I will check the pin and make sure its not a case of just removing road debris and if not then I will just get sorted next time pads need replacing.
The last post was made 16 years, 108 days ago. Instead of replying here, would creating a new thread be more useful? |
