GSXR VS Bandit Cylinder head
soettand
PostPosted: 12:05 - 26 May 2010    Post subject: GSXR VS Bandit Cylinder head Reply with quote
Can anyone tell me, if a Bandit's cylinder head will fit on a GSXR?
Or if the casings of the Cylinder heads are the same.
PostPosted: 13:00 - 26 May 2010    Post subject: Reply with quote
Presuming you mean GSXR1100 oil cooled and 1200 Bandit. Think they will easily (cam chain is different so you need the appropriate cam sprockets to match the crank). You will possibly have issues with the angle the carbs sit at (ie, they might not clear the frame / match up with the airbox).
Not sure the old slab side GSXR11 head cam be put on like that.
Popular mod seems to be to put a head from a GSX750F onto a Bandit to get higher compression (so called dot heads, as there is a 1cm cast on dot on the side of the head).
You are best off asking on https://www.oldskoolsuzuki.info as there will be people on there with far more knowledge on the details.
soettand
PostPosted: 13:11 - 26 May 2010    Post subject: Reply with quote
Thanx, will check with those guys
The last post was made 16 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.47 - MySQL Queries: 15 - Page Size: 35.3 Kb
