Front sprocket fell off whilest riding!!!
Stowelly
PostPosted: 17:12 - 26 May 2010    Post subject: Front sprocket fell off whilest riding!!! Reply with quote
Ok I have a honda NSR 125, when it came to changing the chain and sprockets, id noticed that the previous owner had left the front sprocket on there, with no screws and no retainer clip (i had done over 2000 miles at this point) quite worrying, so put some fresh screws and new retainer clip in (done as tight as possible).
now im riding along today and all of a sudden lose all transmission, have to get the bike recovered, just got the fairing off and had a check, both the screws and the retainer clip where again missing, and the sprocket caught in a part of the frame.
any idea how this could happen?
in the gunk covering the sprocket cover it does look like there are a hell of a lot of bits of metal that looks identical to that of the screws, surely they couldnt just disintigrate though?
nightmare!!!!
PostPosted: 17:30 - 26 May 2010    Post subject: Reply with quote
Those clips can come off easily. Had it happen a few times in the past (Honda seem to be the main ones using them, but not the only ones). Best to put loctite on the bolts between the clip and the sprocket.
Damon
PostPosted: 17:31 - 26 May 2010    Post subject: Re: Front sprocket fell off whilest riding!!! Reply with quote
It's quite possible the bolt got caught inbetween the chain and sprocket both destroying the bolt and moving the sprocket off the shaft. Did it have a lock tab washer behind it or was it just a clip? I really can't see how it happened unless you only fingertightened the bolt Neutral
Can you get a pic of your front sprocket. It would be interesting to see the setup.
Damon
Frost
PostPosted: 17:35 - 26 May 2010    Post subject: Reply with quote
The sprocket and clip will easily get covered in chain lube, which is designed to stop stuff gripping. Clean it all with some petrol and a tooth brush before putting it back together.
Check your chain tension. A loose chain whipping about could help shake the sprocket and bolts loose.
As said above loctite helps.
Stowelly
PostPosted: 17:37 - 26 May 2010    Post subject: Reply with quote
thanks Keith, will keep that in mind!
Damon: cant get to the bike right this second, but could get a pic later if it is that important.
but basically it has the sprocket itself
this clip goes over it
https://images.wemoto.com/full/SPROCKET_FRONT_RETAINER/10004275.jpg
and then twists to the side behind some teeth to lock it in place, then this is screwed to the procket itself
https://www.kazumaracing.com/images/imagecache/375-283-FRONT%20SPROCKET02%28530-12T%29PANTHER200MD.jpg
Damon
PostPosted: 19:38 - 26 May 2010    Post subject: Reply with quote
Ahh I see...
As above I would recommend a strong threadlock. Is the thread on the sprocket ok? If it was chewed up and not a close fit it could cause the bolts to vibrate out.
Stowelly
PostPosted: 19:43 - 26 May 2010    Post subject: Reply with quote
Damon wrote:
Ahh I see...
threadlock?
was a brand new sprocket, and didnt notice anything odd with the thread.... well no different to any other screws on the bike!
is quite worrying that this could happen! quite fortunate the chain didnt lock up, was going quite quick round a tight corner when it happened
Damon
PostPosted: 20:49 - 26 May 2010    Post subject: Reply with quote
Stowelly wrote:
threadlock?
Threadlock
https://www.rap4.com/images/Threadlocker/Loctite_Threadlocker_Red.jpg
can be bought here
https://cgi.ebay.co.uk/Threadlock-High-grade-Thread-lock-Large-10ml-bottle-/360185554547?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item53dcbb6673
PostPosted: 21:31 - 26 May 2010    Post subject: Reply with quote
Be warned that the red loctite in the photo is designed as 'permanent' threadlock. If you intend to ever remove bolts with threadlock on them you should use the blue one.
PostPosted: 21:39 - 26 May 2010    Post subject: Reply with quote
Also known as Loctite 243 Thumbs Up
neil.
PostPosted: 22:55 - 26 May 2010    Post subject: Reply with quote
Very lucky indeed...
Looks like the same mechanism as the YBR. Never had these bolts loosen or drop out though, but last time I changed the C&S (2nd time overall), I used 243 on the threads as I read about tgis happening and was paranoid. Are you torque-ing them up properly as well? Also, I had the opposite problem to you last time I took the front sprocket off - a stuck screw which I rounded off the head of...
ZRX61
Victor Meldrew
PostPosted: 00:22 - 27 May 2010    Post subject: Reply with quote
Pete. wrote:
use the blue one.
What he said.
Stowelly
PostPosted: 14:02 - 27 May 2010    Post subject: Reply with quote
this is red but is 243. is it ok to use?
thanks
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_199465_langId_-1_categoryId_165691
neil.
PostPosted: 15:26 - 27 May 2010    Post subject: Reply with quote
Stowelly wrote:
Yes that's it, and you'll find that the liquid inside the tube is blue! Wink
Watdafukhappe... This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
The last post was made 16 years, 107 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 88.71 Kb
