spray paintign bodywork
Welshd1k
PostPosted: 13:47 - 27 May 2010    Post subject: spray paintign bodywork Reply with quote
is there any special preperation? i got a solo cowl with damage to the paint and want to repaint it. would i be better of sanding it all down and startign afresh? i know the colour i need .
so for abs plastic i assume i need some special primer? then a few coats of colour then a top coat ??? any help is good never sprayed anything other than an exhaust with vht
cb1rocket
PostPosted: 13:56 - 27 May 2010    Post subject: Reply with quote
its generally as said on the back by most spray cans
roughen it a bit
spray on 3 THIN layers of primer
leave to harden over 24hrs
roughen up again with a bit of wet and dry (fine grade)
spray on 3 coats of paint, agan very thin and about 30 mins between coats - don't let it drip then leave overnight
lightly rub down then apply lacquer, again very thinly, its runs quite easily about 3 coats
then leave for another 24-48 hrs and then polish to bring up the shine if necessary
Thats how i been taught, its boring and very time consuming!
let us know the results
locked
PostPosted: 13:57 - 27 May 2010    Post subject: Reply with quote
sand it down to remove all the shit on grime, 2 layers of plastic primer leaving it to dry between each layer.
3 layers of paint, again leaving it to dry between eat layer and then 2 layers of lacquer.
Rub down in between layers if you need to, to get rid of any inperfections that appear but the most important part is make sure wherever you are spraying the plastic in it should be dust free!
1 little speck of dust will fuck up your work and then you have to do it all again Thumbs Up
locked
PostPosted: 14:05 - 27 May 2010    Post subject: Reply with quote
What he said, it can be a pain in the arse
Welshd1k
i dont expect perfection its just a seat cowl that will be on for 'now and again'
The Tot
PostPosted: 09:34 - 28 May 2010    Post subject: Reply with quote
I resprayed my seat cowl and hugger because it got crudded up after a year and half of abuse. It was orginally in honda ross white, so I wanted to touch up any scuffs that couldn't get polished out.
Gave the existing layer a rub down with 800 grit.
Then I went with 4 coats of paint leaving 40 minutes between each coat. Didn't bother sanding in between layers
Left it a day.
Removed the sheen with 1200 grit
Then 3 coats of primer.
Never argue with autism
m0l0t0v
PostPosted: 11:01 - 28 May 2010    Post subject: Reply with quote
You primered after you painted? Laughing
Do you mean lacquered?
salty21
PostPosted: 18:19 - 28 May 2010    Post subject: Reply with quote
i was just thinking that Laughing
st3v3
PostPosted: 18:25 - 28 May 2010    Post subject: Reply with quote
I did my new NS cowl a while go,
Sanded with 600 paper to remove crap and iffy paint
Sanded with 1100 (wet and dry) to get a smooth mint finish
Cleared of dust etc
Sprayed with eve coat of primer
Dried, (maybe should of sanded a tad too)
Painted with 2 coats of cherry red
Dried, lacquered then polished with T cut. Thumbs Up
m0l0t0v
PostPosted: 23:06 - 28 May 2010    Post subject: Reply with quote
You polished with t-cut? Neutral
That just doesn't even make sense!
st3v3
PostPosted: 23:52 - 28 May 2010    Post subject: Reply with quote
went off this:
Imagine T cut as a extremely fine sandpaper or wet and dry silicon carbide paper. It gently rubs the surface of the paint to smooth out scratches and imperfections.
m0l0t0v
PostPosted: 00:36 - 29 May 2010    Post subject: Reply with quote
You do know t-cut pretty much dissolves the paint oh so slitghly to spread it around to hide scratches, etc?
T-cut goes nowhere near any of my bikes. At least after i learn't how it worked. Rolling Eyes
Frost
PostPosted: 00:58 - 29 May 2010    Post subject: Reply with quote
Pretty damn sure it doesn't dissolve anything it's just a fine polishing grit.
The skill and results have little to do with the spraying of the paint or lacquer, and a hell of alot to do with the prep of the surface.
Once the surface is primed and the primer is perfectly flat hardly any paint is required to color it. If your using alot of color chances are you've not done enough prep and the finish will be dubious no matter what. Lacquer should be sprayed untill it's a continuous coat rather than just speckles, and re-coated in about 20 minutes, no more or less.
Oily fingers are a definite no, as is water.
st3v3
PostPosted: 03:51 - 29 May 2010    Post subject: Reply with quote
Surely it merely takes a fraction'th of a mm off the lacquer to get rid of the visible scratches?
If that's the case, it's still works does it not? Thumbs Up
PostPosted: 11:07 - 29 May 2010    Post subject: Reply with quote
If it did that it'd ruin the paint.
m0l0t0v
PostPosted: 12:05 - 29 May 2010    Post subject: Reply with quote
Ok when i said dissolve i didn't mean it dissolves fully. It's like a very weak dissolvant. Can't fully explain it but i'm sure craig would agree with me in not using it. :p
ZRX61
Victor Meldrew
PostPosted: 21:08 - 29 May 2010    Post subject: Reply with quote
AAAARRRRRGGHHHHH!!!
FFS! Shocked Shocked Shocked Shocked
All of you! JUST SHUT UP!
Good fucking grief.... Rolling Eyes
Edit: except Molotov, at least he knows what product is crap & not to be allowed near paint,
.. but the rest of you.... A litany of misinformation & outright bulshit... Rolling Eyes
PostPosted: 21:33 - 29 May 2010    Post subject: Reply with quote
ZRX61 wrote:
AAAARRRRRGGHHHHH!!!
Wow! What a helpful post Rolling Eyes
You moan about everything already posted, and don't post anything useful yourself.
tutton
PostPosted: 21:57 - 29 May 2010    Post subject: Reply with quote
go zrx61 you mega tyrant!
basically what he is getting at is using tcut is known in the body trade like rubbing sand and grit into the bodywork, its wyy too harsh especially for fresh paint!
Use G3. then g10 then a wax for a good polish up after paint has set..
ZRX61
Victor Meldrew
PostPosted: 23:04 - 29 May 2010    Post subject: Reply with quote
Well, that was part of it....
We also have people saying use "fine" wet & dry....
Fine compared to what exactly?
Then we have people saying use 600 or even 1100 wet & dry.. ..
which is great of you want to be able to peel the paint off after it dries.... Rolling Eyes
Then people saying how many coats to use of primer.... You don't know what the part looks like so he may be able to get away with one coat.. or even none at all....
tutton
PostPosted: 23:07 - 29 May 2010    Post subject: Reply with quote
Ok, for the purpose of making tyrant happy.
Surface prep,
Either scuff up with a grey scotch for paint or red scotch for primer.
if using paper/DA id go 180-240, after all it needs a good surface key to hold paint on remember.
When polishing after painting,
If flatting with a DA use 1500 disc dry, then a 3m trizact disc (makes alot of difference imho)
If flatting by hand use 2000 grit (wet and dry, using wet obv), making sure you dont leave any finger marks in it, go much rougher and youll be putting marks into the paint and not gettin the shine you should be.
ZRX61
Victor Meldrew
PostPosted: 23:13 - 29 May 2010    Post subject: Reply with quote
180-240 before primer...
400 wet before paint...
Or just go 180/240 then 400 before primer
tutton
PostPosted: 23:15 - 29 May 2010    Post subject: Reply with quote
Different everywhere tho,
Back at the old bodyshop we used to go for prepainted parts gettin a spray a quick whip over with 800 Wet and dry,
then a blow off, degrease and touch up with a thou disc in booth if needed and was fine. Meh, been a while as well mate been out of it 2 or so years Laughing
st3v3
PostPosted: 04:57 - 30 May 2010    Post subject: Reply with quote
ZRX61 wrote:
AAAARRRRRGGHHHHH!!!
Wooooah easy old man, don't get ya knickers in too tighta-twist now. Neutral
I think you're refering to 'me', and my post was based on practice & success of painting my own fairings, of which I can post pics showing what brilliant-a-finish I have in respect of what I'd aimed for.
The last post was made 16 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 132.2 Kb
