r1 forks in a r6
Ben.
PostPosted: 14:15 - 27 May 2010    Post subject: r1 forks in a r6 Reply with quote
Right im thinking of sticking better forks on my r6. As far as i know the only forks that will fit are 00-01 r1 forks.
It involves putting r1 forks in, r1 yokes, r1 brakes, r1 wheel and an r1 mud guard. You keep the r6 steering stem (the r1 is about an inch longer).
Now its going on to a track bike (plan on putting better springs in the forks) so I want to know if this is a good idea.
My take on it:
pros:
Stronger forks, better brakes, higher tyre profile which will help turn in.
cons/ problems:
ride hight - although this can be solved by having the top of the forks sticking out of the top yoke.
frame - although it wasn't designed for USD forks,, I would of fault it would be able to handle them.
expensive - compared to sticking better springs in r6 forks.
I dont know about the rake angle, but if i keep the ride hight the same it shouldn't change. Although would i be able to change the angle by adjusting the fork hight for better tip in.
missed anything?
Can we keep random comments from people who dont work on bikes, or have good bike knowledge to a minimum please.
follow my racing season
Race bike - R6
Road bike - sv650
PostPosted: 14:19 - 27 May 2010    Post subject: Reply with quote
Personally I'd just whack a cartridge kit in and be done with it.
Also means you'll have to change it back to stock if you want to race it in supersport/superstock 600 classes.
O, and I didn't think a 70 profile rubbed on the mudguard anyway?
Ben.
PostPosted: 14:30 - 27 May 2010    Post subject: Reply with quote
it doesn't rub but its so close its ridiculous.
Don't think it would be able to keep up in superstock anyway so thinking of running pre injection where you can do what ever you want.
Was thinking r1 forks have better damping etc, (if i do do it ill re cartridge the r1 forks)
By the time I've bought new brake discs, springs etc for the r6 forks, its hardly any more money to put r1 forks on....
Just wondering if there is any performance increase or not...
Race bike - R6
Road bike - sv650
PostPosted: 14:41 - 27 May 2010    Post subject: Reply with quote
I heard that R1 forks aren't actually that good. They have extra travel to cope with the power of the R1 and to help prevent tankslappers. This would mean that they won't work well on other bikes.
There must be better choices of fork that will fit the R6. I'd have guessed that (despite being RWU forks) the R6 forks are actually better quality than the R1 ones...
White un
PostPosted: 16:52 - 27 May 2010    Post subject: Reply with quote
How about USD's from a newer R6 ? Wouldn't they be better suited with having similar frame and power ?
Ben.
PostPosted: 17:13 - 27 May 2010    Post subject: Reply with quote
Don't know if new R6 forks will fit...
Race bike - R6
Road bike - sv650
PostPosted: 17:16 - 27 May 2010    Post subject: Reply with quote
What's lacking in these 1999 R6 forks? Surely they aren't that shite.
PostPosted: 17:20 - 27 May 2010    Post subject: Reply with quote
The Brakes on them are top notch and as far as I'm awhere are different between the r1/r6 (calipers anyway) its the same calipers as my TDM and they are amazingly good.
Ben.
PostPosted: 17:22 - 27 May 2010    Post subject: Reply with quote
bike stoppie's way too early, and i want to upgrade the brakes...
they aren't bad per say, I was just wondering instead of spending £500 on brakes and fork upgrades, would it be better to stick an intirley new set on for say £700
Race bike - R6
Road bike - sv650
PostPosted: 17:54 - 27 May 2010    Post subject: Reply with quote
I thought the R1 brakes were pretty much exactly the same from that year.
I've owned and ridden stock and sorted R6s on track. The sorted R6 didn't make a massive difference compared to my skill level.
R1 from that year didn't have noticably better brakes.
The stock R6 brakes in good nick with braided hoses are VERY good to my mind, not have much better even on much more recent bikes. Ie quite like the Nissin radial calipers on my 675 race bike, but not sure they're actually better than decent early R6 brakes.
The forks may be set up a bit soft for you. First off, have you set up the preload? Maybe turned up the compression a little.
£500 spent on sorting the internals of R6 forks will I expect make them a hell of a lot better (relatively - in the real world they should be decent as stock, so not so much releveance) than a stock R1 front end stuck on.
What's inside is what matters and the R1 stock suspension isn't that amazing.
I'd be surprised if the forks stick straight in - I presume you're swapping yokes?
As an idea for swapping forks, it cost me £50 (skimmed spindle) + 2 bearings to make some chunky KTM/CCM yokes/forks fit in to a C90 - most front ends can be swapped with a little effort.
The tyre profile is nothing to do with this really - can fit one on an R6 easily enough.
Not sure why you'd need stronger forks Confused - sure they may do better in a crash, but that may also mean they bend the frame instead.
PostPosted: 18:15 - 27 May 2010    Post subject: Reply with quote
Surely that is suspention/chassis rather than the brakes themselves.
The blue spots are amazing calipers I have no idea how the TDM can stop so quick.
Ben.
PostPosted: 18:23 - 27 May 2010    Post subject: Reply with quote
The brakes out perform the suspension as it is, let alone when i put new discs etc on it.
I plan on sticking better springs on the r1 forks if i put them in.
Race bike - R6
Road bike - sv650
PostPosted: 18:37 - 27 May 2010    Post subject: Reply with quote
I've just realised. You have absolutely no idea what you're talking about.
You just want it for the tart factor don't you? Its OK to admit it. You have no idea if R1 forks and brakes are actually better. I don't think they are.
I think there is enough adjustment in the standard 1999 R6 forks to sort out any woes you have. Maybe some fresh oil and bushes and they should be excellent. I can almost guarantee that any issues you have with the bike however are in your head and not in the forks.
PostPosted: 18:43 - 27 May 2010    Post subject: Reply with quote
If the bike stoppies way too early then you already have more than enough brakes for the chassis. So upgrade the chassis, in this case the forks. Give them to someone who knows what are they doing and it should improve matters. I don't personally think that R1 forks are THAT much better.
For me I think R6 forks with race internals catridge kit + scorrect springs for your weight will outperform R1 forks with new springs.
Ben.
PostPosted: 18:56 - 27 May 2010    Post subject: Reply with quote
hmm think I've got the answer.
To say the brakes out perform the suspension isn't true, it can be sorted out with better springs and sorting out the set up.
The reason I was asking about the r1 forks was, before I spent a lot of time and a bit of money sorting out the stock forks, I thought it might be better to invest a bit more time and money into the r1 set up. Having looked at the actual components inside the r1 forks, its true what your all saying, its hardly any different. I also presumed the r1 brakes would be better but by the sound of things they aren't.
So in answer to the question, yes I think they look better, I also thought they were vastly different (which they aren't), its not worth the extra weight and money on them by the sounds of things, so i think I'll be sticking to stock forks (not going to put later model r6 forks on purely because its going too cost too much even if they will fit)
Race bike - R6
Road bike - sv650
PostPosted: 19:21 - 27 May 2010    Post subject: Reply with quote
Good decision, you know it makes sense. Thumbs Up
Spit-Fire
PostPosted: 23:52 - 27 May 2010    Post subject: Reply with quote
your pros list was shorter then your cons
when ever thats the case, the idea probably aint a good one Thumbs Up
they say the good die young... i say we just live faster
The last post was made 16 years, 115 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.79 - MySQL Queries: 13 - Page Size: 99.77 Kb
