Blowing fuses
Damon
PostPosted: 19:01 - 27 May 2010    Post subject: Blowing fuses Reply with quote
Hi all, my friend has just texted me telling me that his firestorm will not start. It just blows a fuse as soon as he presses the ignition. Does anyone have any ideas?
Thanks, Karma given as always Karma
PostPosted: 19:03 - 27 May 2010    Post subject: Reply with quote
Put a more manly fuse in there, or simply bridge the gap with a bit of wire. Razz
In all seriousness is the fuse of the correct rating that he's replacing the blown one with?
Damon
PostPosted: 19:15 - 27 May 2010    Post subject: Reply with quote
I've done the old tinfoil trick a few times with great success.
Just text him, I don't think he is dim enough to replace the fuses with anything with a lower rating than the original though Neutral
EDIT: used same rated fuse. He says he pressed the ignition and it turned over twice and then blew the fuse.
PostPosted: 19:36 - 27 May 2010    Post subject: Reply with quote
Blowing the main fuse?
Has he checked the wires on that circuit to make sure they aren't shorting on the frame or anything(If the insulation's been rubbed through)?
TUG
PostPosted: 19:43 - 27 May 2010    Post subject: Reply with quote
REG/REC.
Haz ER-5, innit!
The last post was made 16 years, 79 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 2.78 - MySQL Queries: 13 - Page Size: 43.89 Kb
