| scottyn |
 scottyn L Plate Warrior
 Posted: 21:19 - 27 May 2010 Post subject: RS 125 starting and reving problems |
Hi People
ive just got myself an rs125
ive had a new battery fitted
it starts but with loads of revs and after it wont tick over on its own
i have to hold the revs to keep it running
please need help asap
cheers |
| oldbiker |
 oldbiker Nitrous Nuisance
 Posted: 21:40 - 27 May 2010 Post subject: |
It sounds like carb problems, get a manual "on-line". Then check that you have the air screw and needle etc set as they should be and that the throttle and choke cables correctly adjusted.
If that doesn`t sort it, you should check for the most common problems;
1.fuel starvation (caused by kinked fuel lines or crap in the fuel lines. or very rare on newish bikes faulty fuel tap).
2.air leaks around the carb rubbers and manifold.
3. strip and clean the carbs using compressed air to clean the jets and airways, also check that the floats are set to the correct height.
I`m sure others will offer far more advice but that is where I`d start ____________________ It`s all powerfull white mans magic
https://i897.photobucket.com/albums/ac178/tzrsteve/album%201/035.jpg |
| stirlinggaz |
| scottyn |
 Posted: 19:11 - 28 May 2010 Post subject: re: Thanks |
hi guys
thanks for the help and tips its running good now
| SkyJetDisaste... |
 SkyJetDisaste... Two Stroke Sniffer
| pie19850789 |
 pie19850789 L Plate Warrior
 Posted: 15:51 - 20 Jun 2010 Post subject: rs starting problems |
i have an rs 125 2001 model. Chain snapped on me got the bike home, started it few days later to try keeping charge in the battery, worked ok,
few days later went to start again put choke on, started it up i got a lil power on the throttle then it cut off, since them it has never started again,
Firts i thought i had flooded it, tuck plug out fired it over, no fuel came shootin out, tried again, still no joy
Replaced the plug still no joy, checked the spark thats good, still no joy, im now going to clean the carb and air filter.
Does any1 have any advise for me??
some1 told me when a chain snaps it can knock the engine out of timing!! is this true?? could this be y it wont start
HELP PLZ!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
| stirlinggaz |
 Posted: 01:37 - 21 Jun 2010 Post subject: Re: rs starting problems |
| pie19850789 wrote: | i have an rs 125 2001 model. Chain snapped on me got the bike home, started it few days later to try keeping charge in the battery, worked ok,
as said in other post, charge the battery up,
cheers,
GAZ |
The last post was made 16 years, 25 days ago. Instead of replying here, would creating a new thread be more useful? |
