| MarkJ |
 MarkJ World Chat Champion
| Ben. |
 Ben. World Chat Champion
 Posted: 00:39 - 28 May 2010 Post subject: |
the only reason i can think of is because of the tread, when its run backwards it wont displace water properly, but this wont be an issue on the track...
I wouldnt risk it to be honest
pro:
save £120
cons:
it may cause the bike to crash at speeds of excess over 100mph. The crash would most likely be mid corner as well or while braking, which means it may be a high side or at a very fast speed.
worth the risk? ____________________ follow my racing season
Race bike - R6
Road bike - sv650 |
| Bishbash |
 Bishbash World Chat Champion
 Posted: 11:13 - 28 May 2010 Post subject: |
I remember that thread, it was Big Ham I think who was asking or answering, result was it would be fine to do as long as it is dry. As said above it will reverse the tread and water will not dispurse as it should.
It is a good idea as most UK tracks have a majority of right hand bends on the circuit. Just make sure it is dry.
 ____________________ My current bikes are - YZF-R1 & GS 500 E
Trackday videos - https://www.youtube.com/user/bishbash13 |
| MarkJ |
| Bishbash |
 Posted: 11:33 - 28 May 2010 Post subject: |
Never heard that before, but then again I have never tried it, I would only think that would happen if you were really pushing the limits on your tyre.
PM Big Ham, he might know a bit more about this. ____________________ My current bikes are - YZF-R1 & GS 500 E
| G |
 G The Voice of Reason
 Posted: 11:45 - 28 May 2010 Post subject: Re: Running tyres backwards |
Done it loads of times to get a bit of extra life out of a tyre. Getting rid of water isn’t a big issue under normal use with motorbike tyres and definitely not for supercorsas.
It’s worth keeping an eye on the join line – a band going across the tyre where the two ends are glued together bascially.
This is done at an angle, which means that while riding with it on the right way around it’s effectively pushing down compressing the join together. The other way around, it’s kinda pulling up on the join. Never seen it happen, but apparently it’s possible it can start to pull the tread up from there.
Not sure where ben.'s 'con' comes from .
Remember while a tyre is turning one way, it’s still designed to have forces applied at all sorts of different angles. |
| tatters |
 tatters Exxon Valdez
 Posted: 12:01 - 28 May 2010 Post subject: |
Common for enduro/motocross tyres to reverse them half way through so you get even wear on the knobs.
l fitted a dunlop tyre backwards by mistake on my YZF750 and could,nt be arsed to redo it, had no problems apart from a increased lack of grip in the wet. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| D O G |
 D O G World Chat Champion
| Kickstart |
 Kickstart The Oracle
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
| Luke_Retrofly |
 Luke_Retrofly Silly Lesbian
 Posted: 17:06 - 28 May 2010 Post subject: |
Done it to my Minitwin with supercorsa's all the time, never had a problem  ____________________ Flounced - Long overdue
Fuck you bitch I'm in the top 10 list I can do the what the fuck I want! |
| D O G |
| stigger |
 stigger Crazy Courier
The last post was made 16 years, 104 days ago. Instead of replying here, would creating a new thread be more useful? |
