Yamaha YZ125 powerband
stylishboss
PostPosted: 09:46 - 28 May 2010    Post subject: Yamaha YZ125 powerband Reply with quote
I bought a CR125 and a YZ125 but the YZ's powerband does not pull closely as well as the CR's powerband. Is there something I can do or set to correct this?
Tattoo Artist
PostPosted: 10:40 - 28 May 2010    Post subject: Reply with quote
lol, theres nothing you can do, im gunna stay away from the powerband jokes
just enjoy what u have
The Artist
PostPosted: 10:56 - 28 May 2010    Post subject: Reply with quote
I was soooo tempted.
Each bike is different and changing the powerband means changing the fuelling slightly which is not easy unless you have the right kit.
Tattoo Artist
PostPosted: 12:58 - 28 May 2010    Post subject: Reply with quote
i was hoping somebody would lol
PostPosted: 13:21 - 28 May 2010    Post subject: Reply with quote
There different bikes, therefor they have different powerband.
Before you lot start getting moist about powerband jokes, the OPS as used them in the correct way.
Both are highly tunes MX bikes with approaching 30bhp,
Even thought the CR may feel quicker it might be because the Yz has more power lower down and its powerband not as pronounced.
You would alter the Powerband by changing the expansion chamber and porting in the engine I believe.
stylishboss
PostPosted: 18:46 - 28 May 2010    Post subject: Reply with quote
I see that the needle that is in the slide of the carburetor is set to the lowest position, do you think it will give it more power if I set the needle higher because then it should get more fuel?
Noxious89123
PostPosted: 20:40 - 28 May 2010    Post subject: Reply with quote
Unless it's running lean, I wouldn't have thought so. More fuel doesn't always mean more power, you need more air to burn with it, else you'll just be running your bike too rich.
The last post was made 16 years, 78 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.64 - MySQL Queries: 16 - Page Size: 53.35 Kb
