| Billing |
 Billing World Chat Champion
 Posted: 23:27 - 27 May 2010 Post subject: 2 annoying niggles, CBR400 NC23 |
Hi all, my CBR has 2 small problems which don't seem to be particularly damaging, but are annoying all the same.
1- When starting from cold (i.e left overnight) the bike fires up fine, but will die if you don't hold the throttle open a little. This happens no matter what the position of the choke, I know the choke is working because I had to use it a week or so ago. This problem goes away after literally 5 or so seconds, and the bike will idle happily after this point, it also doesn't happen if the bike is slightly warm (i.e left for 15 minutes) What could cause this, and what can I do to fix it please?
2- After I changed my exhaust system last monday (mild steel was changed for stainless) I have noticed that there is a metallic rattling coming from the bike. This happens at 5k to 6k, in any gear or neutral, with the throttle on or off. I have been told that stainless systems can sometimes do this, and not to worry too much, is this true? If not then what should I be looking for? I have been all over the bike making sure things are tight, and so far I haven't found anything loose  ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
BCF Eastern members map here ---> g.co/maps/2tm8b PM me to be added to it! |
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
 Posted: 23:54 - 27 May 2010 Post subject: Re: 2 annoying niggles, CBR400 NC23 |
| BillingTZR wrote: | Hi all, my CBR has 2 small problems which don't seem to be particularly damaging, but are annoying all the same.
2- After I changed my exhaust system last monday (mild steel was changed for stainless) I have noticed that there is a metallic rattling coming from the bike. This happens at 5k to 6k, in any gear or neutral, with the throttle on or off. I have been told that stainless systems can sometimes do this, and not to worry too much, is this true? If not then what should I be looking for? I have been all over the bike making sure things are tight, and so far I haven't found anything loose  |
1. Dunno
2. Where is the rattling coming from? Can't see why an exhaust system would rattle if it fits properly, isnt touching another part of the bike and is on securely.
If the noise comes from one side of your engine (whichever side your cam chain is on) then I would suggest it could be a cam chain tensioner gone dodgy.
If the 400s are anything like the 600s then the cam chain tensioner lifters (CCTs) are made of cheese and go rattly if you look at them wrong. Changed mine a year ago - sorted out a really annoying rattle (like a stones rattling in a tin can) between 5-6k. |
| Billing |
 Posted: 00:04 - 28 May 2010 Post subject: |
nothing is loose or touching, so a bit confused as to what it could be. 100% not possible it could be the CCT, it doesn't have or need one!
cam gears ftw  ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
| temeluchus |
| Phoenix |
 Phoenix Twisted Firestarter
| Grimnir |
 Grimnir Trackday Trickster
| Freaky_1 |
 Freaky_1 Nova Slayer
| Phoenix |
The last post was made 16 years, 38 days ago. Instead of replying here, would creating a new thread be more useful? |
