MySQL help
Phil.
PostPosted: 22:27 - 28 May 2010    Post subject: MySQL help Reply with quote
Hey
I have a query with a few joins that pulls a bunch of data and a datetime field lets call it 'this_date'.
I am adding ORDER BY this_date DESC if a checkbox is selected.
This produces the orders in something like the following order:
2010-05-28 00:00:00
2010-05-27 00:00:00
0000-00-00 00:00:00
etc
However I need them ascending but starting with an actual date, rather than a few pages of '0000-00-00 00:00:00' then ascending dates.
Without having to rewrite a few scripts, is there any MySQL trickery to add some conditions to datetime ordering?
Thanks
PostPosted: 23:49 - 28 May 2010    Post subject: Reply with quote
Do you want those rows with the empty dates listed at all or do you want to drop them? If you don't care about those rows then just use WHERE this_date > 0 (assuming it is a timestamp).
herulach
PostPosted: 08:27 - 29 May 2010    Post subject: Reply with quote
What Keith said, or, if you need to display them, something like:
Code:
cast (case
when date > 0 then date
else "SOMETIME IN THE DISTANT FUTURE"
as datetime ) as 'SortingDate'
then order by your new field.
Depending on your table, it might be faster to do 2 queries, drop the 0s from the first one, then append a second query including only the zeros.
YBR 125>FZS600
Phil.
PostPosted: 10:33 - 29 May 2010    Post subject: Reply with quote
Yes, I do need to pull all the records, including those with empty dates.
To help explain it here's a working query:
Code:
SELECT `orders_id` , `due_by_date` FROM orders WHERE `orders_status` = '2' ORDER BY `due_by_date`
The actual one is much bigger but this shows the problem. Due dates are set by the user (on a small number of orders). The default for 'due_by_date' field is '0000-00-00 00:00:00'.
I need to pull all the orders as in the query above, order them by due_by_date. The query above pulls about 500 rows, order by due_date desc will produce results like in my OP. This isn't ideal for the user, really they need to be ASC, but that puts all the results with '0000-00-00 00:00:00' first which is even worse.
So instead of:
2010-05-28 00:00:00
2010-05-27 00:00:00
0000-00-00 00:00:00
I need:
2010-05-27 00:00:00
2010-05-28 00:00:00
0000-00-00 00:00:00
Hope I have done a better job of explaining it this time.
Thanks for the suggestion Herulach, I'm not familiar with the syntax though, any chance you could amend the above with your suggestion and I will give it a run, see what impact it has on the speed of the query?
Thanks for the help as always.
supZ
PostPosted: 16:11 - 29 May 2010    Post subject: Reply with quote
Code:
cast (case
i dont believe that would work.
at least in mssql it would whinge you're trying to convert a date to a string (in other words you're trying to order a date and string field type)
if it were me i think id add a silly date to it (like 01/01/4000) then use your code (im presuming you're displaying this in a webpage using php) to change it.
e.g.
Code:
select name, (case when duedate = '19000101' then '40000101' else duedate end) as 'showdate'
from testable
order by showdate
replace your field names and table names with the correct ones of course
then replace the 19000101 with your 0 date so what the query will do is, when it finds your 0 date it'll change it to 01/01/4000 (for display only)
dont mind the fact the dates are backwards. i always use ISO formatting when using dates in MSSQL so theres never any region confusion between date formats.
so in your code you'd want something along the lines of 'if the date = 01/01/4000 then display "date not set"'
havent done php in years so im not gonna try to do the syntax but hopefully you get the idea.
the idea behind this is by adding a silly large date to your 0 dates they'll always be at the bottom of your query and you can order them as you want.
CBR954RR - Daily toy
CBR600RR - Trackbike
Alexio
PostPosted: 16:28 - 29 May 2010    Post subject: Reply with quote
Or if you're feeling really lazy you could always just execute two queries. One where date_time != '0000-00-00 00:00:00' and one where date_time = '0000-00-00 00:00:00'.
Now you have two data sets which you can just process one after the other, still have all of the data you required and everything in the order you wanted too.
Only a small bit of extra overhead performance Wink
Frost
PostPosted: 17:25 - 29 May 2010    Post subject: Reply with quote
Performance isn't everything. Maintainability and clarity is everything. So many times i've seen someone try to do something really complex with a single 50 line quirey, yeah its quick, but i don't have a fucking clue how to change it to incorporate some new change. Laughing
Phil.
PostPosted: 10:20 - 30 May 2010    Post subject: Reply with quote
Thanks for all the replies.
I thought maybe there would be a really simple way of having MySQL do what I needed, but it seems like the simplest solution seems to be duplicating the queries and array merge when they are done.
No big deal, seemed like an interesting problem and thought I might be able to learn something out of asking.
Thanks for all your time.
herulach
PostPosted: 17:48 - 30 May 2010    Post subject: Reply with quote
supZ wrote:
Code:
cast (case
e.g.
Code:
from testable
order by showdate
Thats what I meant except I couldn't remember the proper date syntax. Date >0 should work though, if you just compare a date to a number it does it unformatted.
OP - Keith's code I've quoted above will work fine, and should be reasonably easy to understand afterward - just stick a comment if you're worried about someone else understanding it.
At the risk of sounding flippant, the best way to sort it is to require an input into the Due By date that isn't 1900. A test for the date being in the future at the time of input should be sufficient.
Depending on how your frontend will handle DB errors:
Code:
ALTER TABLE orders
ADD CHECK (due_by_date>NOW())
should work, but if you've no error handling it might balls it up.[/code]
YBR 125>FZS600
supZ
PostPosted: 23:10 - 30 May 2010    Post subject: Reply with quote
good point, well made Smile
Alexio
PostPosted: 04:15 - 31 May 2010    Post subject: Reply with quote
https://i8.photobucket.com/albums/a27/alsweetex/forum/mysqrl.jpg
Yeah, I guess there was no really simple way to do it in one query, but there are definitely ways it can be done. I'm sure you could just include some extra documentation / comments.
PostPosted: 13:00 - 01 Jun 2010    Post subject: Reply with quote
Most solutions are going to be lousy on performance as you will land up sorting on a derived field. Reading it into php and then sorting will also be lousy.
You could try this:-
Code:
SELECT *
FROM `DateSortTest`
WHERE `SomeDate` >0
ORDER BY SomeDate
UNION (
SELECT *
FROM `DateSortTest`
WHERE `SomeDate` =0
but not convinced that MySQL will maintain the sort order always.
Personally I would be tempted to have a flag to say that the date field has meaningful data in it for that row. Say "PlannedEvent" as a boolean:-
Code:
SELECT *
FROM `DateSortTest`
ORDER BY PlannedEvent, SomeDate
Not strictly good practice (as you are effectively duplicating data) but in this case I wouldn't worry. And you can always use a trigger to force update the flag field is the date field changes.
supZ
PostPosted: 14:44 - 01 Jun 2010    Post subject: Reply with quote
wouldnt have thought it does, MSSQL certainly doesnt.
tried a union myself Wink
PostPosted: 15:00 - 01 Jun 2010    Post subject: Reply with quote
Playing MySQL appears to, but I wouldn't be surprised if it isn't guaranteed to.
Sorting after that would mean using derived fields and would likely be slower, but could be done. Doubt it would be any different performance wise than you CASE suggestion:-
Code:
SELECT *
FROM ((
SELECT Id, SomeDate, '0' AS UseDate
FROM `DateSortTest`
WHERE `SomeDate` >0
UNION (
SELECT Id, SomeDate, '1' AS UseDate
FROM `DateSortTest`
WHERE `SomeDate` =0
ORDER BY UseDate, SomeDate
The last post was made 16 years, 100 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 91.62 Kb
