Rebuilding My GPZ 500s 1998 Model D5
The Blackbaron
PostPosted: 17:54 - 29 May 2010    Post subject: Rebuilding My GPZ 500s 1998 Model D5 Reply with quote
Hi there, I have a couple of questions
Can anyone tell me what mirrors I need that isn't completely useless like the original but doesn't vibrate to bits like other mirrors I have tried?
Also the previous owner of the bike managed to crack the thread in the sump so it's leaking oil. I'm wondering what the best way is to fix that. c_dug you know who you are.
Thanks people!
Dazbo666
PostPosted: 20:20 - 29 May 2010    Post subject: Reply with quote
I had a '91 GPZ500, and I seem to remember that you could get rubber bung type fittings that attached to the base of the standard mirrors.
To be honest though, I never really found an effective way to reduce the vibration on those mirrors.
As for the sump thread, you may need to overbore / re-tap the thread and use a larger size sump plug
Word of the day : DILLIGAF
PostPosted: 21:46 - 29 May 2010    Post subject: Reply with quote
I think one of the GPX mirrors (maybe the 600?) have a longer stem on them and fit on. There were various pattern ones that claimed to give a view of something other than your elbows back in the day.
For the plug. Order a new oil pan gasket. Drain the oil, remove the sump plate. Take it to an engineering shop and get them to fit a helicoil. Reattach it.
I did you screencaps from the workshop manual, it is not a tricky job. Just make sure those o-rings are in the right place when you reassemble it.
You shouldn't need to touch the relief valve. Leave it be.
The last post was made 16 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.53 - MySQL Queries: 13 - Page Size: 36.73 Kb
