Noob rider ???
Tristan.
PostPosted: 12:42 - 30 May 2010    Post subject: Reply with quote
No
When it holds an idle
Learn clutch control
hth
PostPosted: 13:03 - 30 May 2010    Post subject: Reply with quote
Pocket Rocket wrote:
Thanks,#
Sure i'll get there, just stalling in front of cars is annoying .. Thumbs Up
When should i turn petrol off ... ?? ta
dont bother, i never have and never will, unless my GS tap breaks again, then i keep it on Thumbs Up
badas
PostPosted: 14:19 - 30 May 2010    Post subject: Reply with quote
i allways have mine on (even overnight) unless i go out in town and i feel like its not a safe place to keep my bike as such then i will turn it off but only rairly.
PostPosted: 14:47 - 30 May 2010    Post subject: Reply with quote
You'll either be a leave it on or a turn it off bloke.
Mine is on all the time. I know the risks Smile
As for pulling away on a 2T. You'll get there and your clutch slipping skills will improve.
I start with full choke..it fires...i push choke in a bit till it will run slower without stalling. I get on and ride. If it bogs down on throttle i ease more choke off. After about 2mins i can knock the choke off.
[edit] good tip if you flood it is to turn choke off. Open throttle 3/4 and start.
Pat
rac3r
PostPosted: 15:17 - 30 May 2010    Post subject: Reply with quote
Choke on when you start up while putting your lid etc on then off when you start riding. Take it easy until the bike warms up.
Thats what I do Thumbs Up
As for loads of revs to move, I thought 2 strokes were meant to be like that? (chives will know better)
Chequered Flag
waffles
PostPosted: 17:06 - 30 May 2010    Post subject: Reply with quote
With my first bike I stalled it lots, you'll find that bite point soon enough and after a little while will be able to sort it all out without thinking about it.
Just keep at it Thumbs Up
PostPosted: 23:51 - 30 May 2010    Post subject: Reply with quote
My 250 isn't too bad, but then again, it's got twice the cubic capacity.
You may just think you're revving it up loads but you're not. As has been pointed out, just slip the clutch for longer. You'll get used to it.
With regards to the fuel tap, I just got into the habit of turning it off whenever I stopped, just like turning the ignition off. Now I have a bike with a vacuum tap I'll probably forget if/when I start riding the Chaly.
Flip
PostPosted: 23:54 - 30 May 2010    Post subject: Reply with quote
Fuel tap I'd leave on unless you're leaving it for a couple of weeks.
Slip the clutch in first.
It's better to over rev than to under rev.
Full choke at first, than half choke, then turn it off and ride.
(This what I did with a 2 stroke 125, from memory, without any problems.)
Karma
Clanger
Stirrer
PostPosted: 10:54 - 31 May 2010    Post subject: Reply with quote
You remember with such clarity... Shocked Laughing
The last post was made 16 years, 109 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 82.36 Kb
