| rsooty |
 rsooty Spanner Monkey
| Caspar |
 Caspar Two Stroke Sniffer
| Caspar |
 Posted: 15:50 - 13 Jul 2004 Post subject: Apologies for the length... fnurk fnurk! |
This from the Houston Chronicle of all places - does it sound like your problem? (Dunno how useful the answer is, though)
Q. I've recently purchased a new desktop running Windows XP. I installed Microsoft Office 2000 Premium on it shortly after purchasing it. My problem occurs when I'm trying to respond to an e-mail that I've received. When I hit reply, the computer automatically attempts to install the Office software again. After hitting cancel two to three times, the installation stops and I can continue with my reply. If I don't hit cancel, the installation will continue until it realizes there is no CD inserted to continue with the installation.
A. When you do a standard installation of a Microsoft Office, it only installs the standard features, not every feature. Most people do not use all of the software's capabilities. By not installing the whole thing, you conserve disk space.
What is happening here is that Office is looking for a component it needs and you will have to put the CD in the drive and let it pull it off. It should only need to do this once.
With disk space being plentiful these days, you can opt to install the entire application by choosing the custom install option when you first install the program. In your case, where the software is already installed, you can change the install by going to the Add/Remove programs section of the Control Panel and click the Change option for Microsoft Office. From there, you can add all the components and never be prompted again for the CD.
If you do not own the software and installed Office from a borrowed copy of the program, say from work or from a friend, you now see one of the benefits of owning the software. |
| rsooty |
| Bendy |
 Bendy Mrs Sensible
| Mr Pants! |
 Mr Pants! I Karma
| rsooty |
| Caspar |
| rsooty |
| Abb |
 Abb Derestricted Danger
| sychosis |
 sychosis Crazy Courier
 Posted: 17:12 - 13 Jul 2004 Post subject: |
Reinstall Office using the custom option, when you get to a screen with the folders on click on the top one and tell it to run all from my computer. attached is the screen i'm on about. ____________________ Bikes owned: Aprilia RS 125 GP1 2003 (Now sold), Suzuki GSX-r600 1997 (streetfightered), https://www.bikepics.com/members/sychosis/
psy?cho?sis (si-ko-sis),n. pl. psy?cho?ses (-sez) ,A severe mental disorder, with or without organic damage, characterized by derangement of personality and loss of contact with reality and causing deterioration of normal social functioning. |
| Milo |
 Milo World Chat Champion
 Posted: 18:12 - 13 Jul 2004 Post subject: |
I've not read the above but a common cure is to do a full uninstall then run the Microsoft Office 2000 erasor tool - this removes all registry entries and stuff left over from the install.
Restart then do a full install and see if that works.
I assume you're a local admin and not just a "power user"? ____________________ Shaft drives rule.  |
| rsooty |
| mr.z |
 mr.z World Chat Champion
 Posted: 19:15 - 13 Jul 2004 Post subject: |
one thing to try is installing it in safemode (not sure how you xp victims get at it) that way nothing like scumware/spyware might interfeer with its installation, if oyu get the same problem that rules out other rubbishy stuff messing with it. ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| hellkat |
 hellkat Super Spammer
| carvell |
 carvell Scuttler
| hellkat |
| AcIdBuRnZ |
 AcIdBuRnZ World Chat Champion
| Davo |
 Davo Davo To The Rescue!
The last post was made 22 years, 55 days ago. Instead of replying here, would creating a new thread be more useful? |
