yamaha ybr 125 chain help
crunch
PostPosted: 21:26 - 31 May 2010    Post subject: yamaha ybr 125 chain help Reply with quote
Hey Guys
this is my 1st post so wanted to say hi. I have recently got into motorbikes, took my CBT and got a Yamaha YBR 125 to drive to and from work. As im new to bikes im trying to see what i need to check for regularly and keep my bike in good condition.
I have noticed that my chain is very dirty and is in need of a good clean but i just wanted to ask how often or when do i need to actually changed the chain and sprockets? its just had a new MOT and service before it was delivered to me so im assuming that it is ok for now? looking at the sprocket its not too worn and the chain is about 3-4 notches from the end (the indicator etched where you tighten the belt).
Sorry if this is a noob post im just new to all this and trying to learn as i go
PostPosted: 22:06 - 31 May 2010    Post subject: Reply with quote
A workshop manual will tell you measure the length of a certain number of chain links to determine how much the chain has stretched.
But for a rough guide I always see if I can pull the chain away from the rear sprocket at the 3 o'clock position and stick a pencil in the gap. If the pencil fits, its usually replacement time.
neil.
PostPosted: 22:14 - 31 May 2010    Post subject: Reply with quote
You can also tell when the chain has gone when you keep having to adjust it very frequently and it's getting towards the last adjuster mark on the swingarm. This happened to me at around 15'000 miles for the stock chain and sprockets on my YBR, so they do last well, providing you look after them, cleaning and lubricating them regularly (I tend to do it every 500 miles or 2 weeks for me as I cover that distance in that time) as well as keeping the correct slack adjusted. If you ride a lot, in all weather, you might want an automatic oiler such as a Loobman, which I've had great success with on my current chain (covered about 5'000 miles on it and not adjusted it once).
DrDonnyBrago
PostPosted: 23:16 - 31 May 2010    Post subject: Reply with quote
To clean your chain bu a 5l tub of parrafin from B&Q (sold as outdoor lamp fuel for £5) and use a brush and a cloth to scrub and wipe your chain and sprockets clean. I then use engine oil applied with an old paintbrush to lube it up.
Reapply lube every 300-500 miles and clean it when it starts looking rough again.
Tis the cheapest and IMO best way Thumbs Up .
crunch
PostPosted: 07:42 - 01 Jun 2010    Post subject: Reply with quote
Much apreciated guys! I think I will get myself a manual for this just to learn and will keep an eye on the chain as the bike is coming up to 14k miles. Will give a good clean too!
Mark65
PostPosted: 12:20 - 01 Jun 2010    Post subject: Reply with quote
As Above, but i use gear oil and re oil lightly every 100 mile or when it rains, wipe the chain then rub in with fingers (NO ENGINE RUNNING and the opposite way from sproket), and i keep it at its recommended max of 30mm where its tight at the longest point .
Can relube chain in less than ten min now.
Mark
PostPosted: 12:22 - 01 Jun 2010    Post subject: Reply with quote
the total stretch on a standard YBR chain should not be more than 191.5mm when measured between the first and sixteenth pins on a 15 link section of chain.
(according to the manual)
crunch
PostPosted: 09:55 - 02 Jun 2010    Post subject: Reply with quote
again thanks guys, think i will invest in a haynes manual or something for the bike sounds like you can learn a lot from it
The last post was made 16 years, 140 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 60.43 Kb
