| Whosthedaddy |
 Whosthedaddy Super Spammer
 Posted: 15:15 - 28 May 2010 Post subject: Bike starts but wont idle, cuts out when not on choke? |
The TRX will start from cold with just a flick of a switch but no sooner started have the revs dropped and cuts out.
If I start with choke then again, fires into action but this time the revs stay at just under 1000 revs / min. A few minutes on the sidestand or even down the road at idle, the revs remain lower than the 'warmed' up idle and have cut out again if not gently blipped.
After a few more miles, no problems, idle at 1,250+ revs.
This is summer? No real problems during the winter as always started on choke, but come on, I shouldn't be needing choke now to this extent?
Its a standard bike with standard cans, service was done a few 1000 miles ago. ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| Crafty |
 Crafty Derestricted Danger
 Posted: 16:13 - 28 May 2010 Post subject: Re: Bike starts but wont idle, cuts out when not on choke? |
[quote="Whosthedaddy"] but come on, I shouldn't be needing choke now to this extent?
Clealy the engine is saying it does need choke then.
Have you tried starting it on full (or even 1/2) choke & then reducing it to so the engine idles @1500rpm once its running?
Unfotunatly the electronic fuel injection systems have ruined the art of knowing how to start an engine the old skool way  ____________________ To FINNISH 1ST, 1ST you gotta FINNISH.
Fastest is the 1ST to CROSS the FINNISH LINE.
2ND, IS the 1ST of all the LOSERS. |
| Jesta_ZX6R |
 Jesta_ZX6R Borekit Bruiser
| temeluchus |
| Whosthedaddy |
| Jesta_ZX6R |
| molex |
 molex Renault 5 Driver
 Posted: 04:45 - 01 Jun 2010 Post subject: |
For my experience "opinion" your TRX start air leak.!
better to check the joint between carburetor and engine
is it old enough to replace the parts.?
How to check air leak
https://www.mikuni.com/pdf/hsr_tuningmanual_021003.pdf
good luck.! |
| Whosthedaddy |
| Jesta_ZX6R |
| molex |
The last post was made 16 years, 152 days ago. Instead of replying here, would creating a new thread be more useful? |
