tdr125 starting issues
Dr. DaveJPS
PostPosted: 16:37 - 01 Jun 2010    Post subject: tdr125 starting issues Reply with quote
Hi my mate has just bought one of these, however he has been unable to get it to run since the last owner delivered it. i had a look today and there is no spark from the plug, however when the ignition is pressed, there is only a servo sound.
thus BCF is this liable to be a starter motor issue?
( i have no idea with 2T engines)
www.davejps.com
PostPosted: 16:43 - 01 Jun 2010    Post subject: Reply with quote
If there is no spark it change the spark plug them work backwards (cap,lead,coil) till you get a spark.
stirlinggaz
PostPosted: 20:10 - 01 Jun 2010    Post subject: Reply with quote
tried charging the battery up?
thats the 1st place i'd start, tick a multi-meter on the battery & press the starter & watch the voltage drop.
it it doesnt go back up to 13v, charge the thing up, then work back from the battery.
cheers,
GAZ
Dr. DaveJPS
PostPosted: 21:13 - 01 Jun 2010    Post subject: Reply with quote
battery is a new one and had been charged afor we tried to start it, also tried bumping it (bump starting in the rain down a cobbled hill with no fluid in the front brakes Pale )
www.davejps.com
stirlinggaz
PostPosted: 21:55 - 02 Jun 2010    Post subject: Reply with quote
next step is to try & see if the spark plug is actually sparking.
take it out & put it into ht cap & earth against frame, whilst hitting starter button.............. is it sparking?
if its not a big fat blue spark, change it for a new one & repeat.
if its not sparking at all, check ht lead & cap.
then work back to starter relay/solenoid then stater motor.
does the starter motor spin when 12v is applied to it?.
cheers,
GAZ
Dr. DaveJPS
PostPosted: 22:09 - 02 Jun 2010    Post subject: Reply with quote
tried that (OP) there is no spark.
cheers,
GAZ
by listening to it from when we tried i'd hazard the starter motor wasn't turning. i was more wondering if it was a known issue with these that any part of the starting circuit that is weak.
www.davejps.com
stirlinggaz
PostPosted: 11:00 - 03 Jun 2010    Post subject: Reply with quote
tried a new plug?
thats usually the 1st thing i check when anything goes wrong on any of my 2t's.
chuck a new plug in,as they do have a habit of failing.
then with a freshly charged battery, start again.
cheers,
GAZ
The last post was made 16 years, 152 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 52.49 Kb
